Elegoo Nano stuck on uploading in arduino ide
My elegoo nano is stuck on uploading. I tried using different pc but nothing. Everything started with an ultrasonic distance sensor project that on the serial monitor the reading said 0cm 0inch. I already did this project some days ago with the same sketch and circuit but now it just doesn't work. I tried uploading it more times until after 5 times it got stuck uploading.
the error code i found looking at other posts is this.
Le variabili globali usano 9 byte (0%) di memoria dinamica, lasciando altri 2039 byte liberi per le variabili locali. Il massimo è 2048 byte.
"C:\Users\studente.TMB05\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\studente.TMB05\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v  -patmega328p -carduino "-PCOM10" -b115200 -D "-Uflash:w:C:\Users\studente.TMB05\AppData\Local\arduino\sketches\70A7626542CF5649849151CE1C3A9DDF/ultrasonic_distance_sensor_led_bar_graph_blocks_1.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\studente.TMB05\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM10
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\studente.TMB05\AppData\Local\arduino\sketches\70A7626542CF5649849151CE1C3A9DDF/ultrasonic_distance_sensor_led_bar_graph_blocks_1.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.15s
avrdude: 924 bytes of flash written
avrdude: verifying flash memory against C:\Users\studente.TMB05\AppData\Local\arduino\sketches\70A7626542CF5649849151CE1C3A9DDF/ultrasonic_distance_sensor_led_bar_graph_blocks_1.ino.hex:
avrdude: load data flash data from input file C:\Users\studente.TMB05\AppData\Local\arduino\sketches\70A7626542CF5649849151CE1C3A9DDF/ultrasonic_distance_sensor_led_bar_graph_blocks_1.ino.hex:
avrdude: input file C:\Users\studente.TMB05\AppData\Local\arduino\sketches\70A7626542CF5649849151CE1C3A9DDF/ultrasonic_distance_sensor_led_bar_graph_blocks_1.ino.hex contains 924 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.12s
avrdude: verifying ...
avrdude: 924 bytes of flash verified
avrdude done.  Thank you.```
Please help
It's not stuck. It finished. Successfully.
No it wasn't but i just solved the problem. I deleted arduino 15 and then system 32 and now it seems working
I stand by what I wrote.
No you didn't, if Arduino15 was deleted then you have NO Arduino environment.
Moreover, although I stopped using Windows almost 10 years ago, I am sure that system32 is a major part of the Windows system.
