Hello
I have a Elegoo Smart car with a built in code
Attached
Its working fine except the turn is very exaggerated. On turning left or right it turns almost a full 180 degrees.
Looking at this script I can't see how to change this.
Any advice greatly received
* @Description: In User Settings Edi
* @Author: your name
* @Date: 2019-08-12 18:00:25
* @LastEditTime: 2019-08-27 10:45:29
* @LastEditors: Please set LastEditors
#include <IRremote.h>
#include <Servo.h>
#include <stdio.h>
#include "HardwareSerial.h"
#include "ArduinoJson-v6.11.1.h" //Use ArduinoJson Libraries
#define f 16736925 // FORWARD
#define b 16754775 // BACK
#define l 16720605 // LEFT
#define r 16761405 // RIGHT
#define s 16712445 // STOP
#define KEY1 16738455 //Line Teacking mode
#define KEY2 16750695 //Obstacles Avoidance mode
#define KEY_STAR 16728765
#define KEY_HASH 16732845
/*Arduino pin is connected to the IR Receiver*/
#define RECV_PIN 12
/*Arduino pin is connected to the Ultrasonic sensor module*/
#define ECHO_PIN A4
#define TRIG_PIN A5
const int ObstacleDetection = 35;
/*Arduino pin is connected to the Motor drive module*/
#define ENA 5
#define ENB 6
#define IN1 7
#define IN2 8
#define IN3 9
#define IN4 11
#define LED_Pin 13
/*Arduino pin is connected to the IR tracking module*/
#define LineTeacking_Pin_Right 10
#define LineTeacking_Pin_Middle 4
#define LineTeacking_Pin_Left 2
#define LineTeacking_Read_Right !digitalRead(10) //Right
#define LineTeacking_Read_Middle !digitalRead(4) //Middle
#define LineTeacking_Read_Left !digitalRead(2) //Left
#define carSpeed 180 //PWM(Motor speed/Speed)
unsigned int carSpeed_rocker = 250;
#define PIN_Servo 3
Servo servo; // Create a DC motor drive object
IRrecv irrecv(RECV_PIN); // Create an infrared receive drive object
decode_results results; // Create decoding object
unsigned long IR_PreMillis;
unsigned long LT_PreMillis;
int rightDistance = 0; //Right distance
int leftDistance = 0; //left Distance
int middleDistance = 0; //middle Distance
/*DIY_MotorControl: Motor Control: Motor Speed、Motor Direction、Motor Time*/
uint8_t DIY_MotorSelection;
uint8_t DIY_MotorDirection;
uint16_t DIY_MotorSpeed;
unsigned long DIY_leftMotorControl_Millis;
unsigned long DIY_rightMotorControl_Millis;
/*DIY_CarControl: Car Control:Car moving direction、Car Speed、Car moving time*/
uint8_t DIY_CarDirection;
uint8_t DIY_CarSpeed;
uint16_t DIY_CarTimer;
unsigned long DIY_CarControl_Millis;
uint8_t DIY_CarDirectionxxx;
uint8_t DIY_CarSpeedxxx;
uint16_t DIY_Distance;
String CommandSerialNumber; //
enum SERIAL_mode
Serial_rocker,
Serial_programming,
Serial_diy,
} Serial_mode = Serial_programming;
enum FUNCTIONMODE
IDLE, /*free*/
LineTeacking, /*Line Teacking Mode*/
ObstaclesAvoidance, /*Obstacles Avoidance Mode*/
Bluetooth, /*Bluetooth Control Mode*/
IRremote, /*Infrared Control Mode*/
DIY_MotorControl, /*Motor Control Mode*/
DIY_CarControl, /*Car Control Mode*/
DIY_CarControlxxx, /*Car Control Mode*/
DIY_ClearAllFunctions, /*Clear All Functions Mode*/
} func_mode = IDLE; /*Functional mode*/
enum MOTIONMODE
STOP, /*stop*/
FORWARD, /*forward*/
BACK, /*back*/
LEFT, /*left*/
RIGHT /*right*/
} mov_mode = STOP; /*move mode*/
void delays(unsigned long t)
for (unsigned long i = 0; i < t; i++)
getBTData_Plus(); //Bluetooth Communication Data Acquisition
getIRData(); //Infrared Communication Data Acquisition
delay(1);
/*ULTRASONIC*/
unsigned int getDistance(void)
{ //Getting distance
static unsigned int tempda = 0;
unsigned int tempda_x = 0;
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
tempda_x = ((unsigned int)pulseIn(ECHO_PIN, HIGH) / 58);
tempda = tempda_x;
// if (tempda_x < 150)
// tempda = tempda_x;
// else
// tempda = 30;
return tempda;
//return tempda_x;
Control motor:Car movement forward
void forward(bool debug, int16_t in_carSpeed)
analogWrite(ENA, in_carSpeed);
analogWrite(ENB, in_carSpeed);
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
if (debug)
Serial.println("Go forward!");
Control motor:Car moving backwards
void back(bool debug, int16_t in_carSpeed)
digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
if (debug)
Serial.println("Go back!");
Control motor:The car turns left and moves forward
void left(bool debug, int16_t in_carSpeed)
if (debug)
Serial.println("Go left!");
Control motor:The car turns right and moves forward
void right(bool debug, int16_t in_carSpeed)
if (debug)
Serial.println("Go right!");
Stop motor control:Turn off the motor drive
void stop(bool debug = false)
digitalWrite(ENA, LOW);
digitalWrite(ENB, LOW);
if (debug)
Serial.println("Stop!");
Bluetooth serial port data acquisition and control command parsing
void getBTData_Plus(void)
String comdata = "";
while ((Serial.available() > 0) && (false == comdata.endsWith("}")))
if (Serial_mode == Serial_rocker)
comdata += char(Serial.read());
delay(3);
else if (Serial_mode == Serial_programming)
delay(6);
else if (Serial_mode == Serial_diy)
delay(6);
if ((comdata.length() > 0) && (comdata != "") && (true == comdata.endsWith("}")))
StaticJsonDocument<200> doc; //Create a JsonDocument object
DeserializationError error = deserializeJson(doc, comdata); //Deserialize JSON data
if (!error) //Check if deserialization is successful
int control_mode_N = doc["N"];
char buf[3];
uint8_t temp = doc["H"];
sprintf(buf, "%d", temp);
CommandSerialNumber = buf; //Get the serial number of the new command
switch (control_mode_N)
case 21: /*Ultrasonic module processing <command:N 21>*/
DIY_UltrasoundModuleStatus_Plus(doc["D1"]);
case 22: /*Trace module data processing <command:N 22>*/
DIY_TraceModuleStatus_Plus(doc["D1"]);
case 1: /*Motion module processing <command:N 1>*/
func_mode = DIY_MotorControl;
DIY_MotorSelection = doc["D1"];
DIY_MotorDirection = doc["D2"];
DIY_MotorSpeed = doc["D3"];
Serial.print('{' + CommandSerialNumber + "_ok}");
case 4: /*Motion module processing <command:N 4>*/
func_mode = DIY_CarControl;
DIY_CarDirection = doc["D1"];
DIY_CarSpeed = doc["D2"];
DIY_CarTimer = doc["T"];
DIY_CarControl_Millis = millis(); //Get the timestamp
//Serial.print("{ok}");
case 40:
func_mode = DIY_CarControlxxx;
DIY_CarDirectionxxx = doc["D1"];
DIY_CarSpeedxxx = doc["D2"];
case 5: /*Clear mode processing <command:N 5>*/
func_mode = DIY_ClearAllFunctions;
case 3: /*Remote switching mode processing <command:N 3>*/
Serial_mode = Serial_rocker;
if (1 == doc["D1"]) // Line Teacking Mode
func_mode = LineTeacking;
else if (2 == doc["D1"]) //Obstacles Avoidance Mode
func_mode = ObstaclesAvoidance;
case 2: /*Remote switching mode processing <command:N 2>*/
int SpeedRocker = doc["D2"];
if (SpeedRocker != 0)
carSpeed_rocker = SpeedRocker;
if (1 == doc["D1"])
func_mode = Bluetooth;
mov_mode = LEFT;
// Serial.print('{' + CommandSerialNumber + "_ok}");
mov_mode = RIGHT;
else if (3 == doc["D1"])
mov_mode = FORWARD;
//Serial.print('{' + CommandSerialNumber + "_ok}");
else if (4 == doc["D1"])
mov_mode = BACK;
else if (5 == doc["D1"])
mov_mode = STOP;
default:
else if (comdata != "")
if (true == comdata.equals("f"))
DIY_CarDirectionxxx = 3;
DIY_CarSpeedxxx = 180;
else if (true == comdata.equals("b"))
DIY_CarDirectionxxx = 4;
else if (true == comdata.equals("l"))
DIY_CarDirectionxxx = 1;
else if (true == comdata.equals("r"))
DIY_CarDirectionxxx = 2;
else if (true == comdata.equals("s"))
mov_mode = STOP;
else if (true == comdata.equals("1"))
else if (true == comdata.equals("2"))
void getIRData(void)
if (irrecv.decode(&results))
IR_PreMillis = millis();
switch (results.value)
case f:
func_mode = IRremote;
mov_mode = FORWARD;
break; /*forward*/
case b:
mov_mode = BACK;
break; /*back*/
case l:
mov_mode = LEFT;
break; /*left*/
case r:
mov_mode = RIGHT;
break; /*right*/
case s:
mov_mode = STOP;
break; /*stop*/
case KEY1:
break; /*Line Teacking Mode*/
case KEY2:
break; /*Obstacles Avoidance Mode*/
default:
irrecv.resume();
Bluetooth remote control mode
void bluetooth_mode()
if (func_mode == Bluetooth)
switch (mov_mode)
case FORWARD:
forward(false, carSpeed_rocker);
case BACK:
back(false, carSpeed_rocker);
case LEFT:
left(false, carSpeed_rocker);
case RIGHT:
right(false, carSpeed_rocker);
case STOP:
stop();
default:
Infrared remote control mode
void irremote_mode(void)
if (func_mode == IRremote)
switch (mov_mode)
case FORWARD:
forward(false, carSpeed);
case BACK:
back(false, carSpeed);
case LEFT:
left(false, carSpeed);
case RIGHT:
right(false, carSpeed);
case STOP:
stop();
default:
if (millis() - IR_PreMillis > 500)
mov_mode = STOP;
Line Teacking Mode
void line_teacking_mode(void)
if (func_mode == LineTeacking)
if (LineTeacking_Read_Middle)
{ //Detecting in the middle infrared tube
forward(false, carSpeed); //Control motor:the car moving forward
LT_PreMillis = millis();
else if (LineTeacking_Read_Right)
{ //Detecting in the right infrared tube
right(false, carSpeed); //Control motor:the car moving right
while (LineTeacking_Read_Right)
getBTData_Plus(); //Bluetooth data acquisition
getIRData(); //Infrared data acquisition
else if (LineTeacking_Read_Left)
{ //Detecting in the left infrared tube
left(false, carSpeed); //Control motor:the car moving left
while (LineTeacking_Read_Left)
if (millis() - LT_PreMillis > 150)
stop(); //Stop motor control:Turn off motor drive mode
/*f(x) int */
static boolean function_xxx(long xd, long sd, long ed) //f(x)
if (sd <= xd && xd <= ed)
return true;
return false;
/*Obstacle avoidance*/
void obstacles_avoidance_mode(void)
static uint16_t ULTRASONIC_Get = 0;
static unsigned long ULTRASONIC_time = 0;
static boolean stateCar = false;
static boolean CarED = false;
static uint8_t switc_ctrl = 0x00;
static boolean timestamp = true;
if (func_mode == ObstaclesAvoidance)
servo.attach(3);
if (millis() - ULTRASONIC_time > 100)
ULTRASONIC_Get = getDistance(); //Measuring obstacle distance
ULTRASONIC_time = millis();
if (function_xxx(ULTRASONIC_Get, 0, 30)) //If the distance is less than Xcm obstacles
stateCar = true;
stop(); //stop
stateCar = false;
if (false == CarED)
if (stateCar == true)
timestamp = true;
CarED = true;
switc_ctrl = 0x00;
stop(); //stop
servo.write(30); //sets the servo position according to the value
delays(500);
if (function_xxx(getDistance(), 0, 35)) //How many cm in the front have obstacles?
switc_ctrl |= 0x01;
switc_ctrl &= (~0x01);
servo.write(150); //sets the servo position according to the value
delays(500);
switc_ctrl |= 0x02;
switc_ctrl &= (~0x02);
servo.write(90); //tell servo to go to position in variable 30
delays(500);
switc_ctrl |= 0x04;
switc_ctrl &= (~0x04);
forward(false, 150); //Control motor:the car moving forwar
CarED = false;
if (true == CarED)
// Get cpu time
static unsigned long MotorRL_time;
if (timestamp == true || millis() - MotorRL_time > 420)
timestamp = false;
MotorRL_time = millis();
if (function_xxx((millis() - MotorRL_time), 0, 400))
switch (switc_ctrl)
case 0 ... 1:
left(false, 250); //Control motor:The car moves forward and left
case 2:
right(false, 250); //Control motor:The car moves forward and right
case 3:
case 4 ... 5:
case 6:
case 7:
back(false, 250); //Control motor:Car backwards
CarED = false;
servo.detach();
ULTRASONIC_Get = 0;
/*****************************************************Begin@DIY**************************************************************************************/
N21:command
DIY mode:Ultrasonic module:App controls module status, module sends data to app
void DIY_UltrasoundModuleStatus_Plus(uint8_t is_get) //Ultrasonic module processing
//uint16_t
DIY_Distance = getDistance(); //Ultrasonic module measuring distance
if (1 == is_get) // is_get Start true:Obstacles / false:No obstacles
if (DIY_Distance <= 50)
Serial.print('{' + CommandSerialNumber + "_true}");
Serial.print('{' + CommandSerialNumber + "_false}");
else if (2 == is_get) //Ultrasonic is_get data
char toString[10];
sprintf(toString, "%d", DIY_Distance);
// Serial.print(toString);
Serial.print('{' + CommandSerialNumber + '_' + toString + '}');
N22:command
DIY mode:Teacking module:App controls module status, module sends data to app
void DIY_TraceModuleStatus_Plus(uint8_t is_get) //Tracking module processing
if (0 == is_get) /*Get traces on the left*/
//Serial.print("{true}");
//Serial.print("{false}");
else if (1 == is_get) /*Get traces on the middle*/
{ /*Get traces on the right*/
N1:command
DIY mode:Sport mode <motor control> Control motor by app
Input:uint8_t is_MotorSelection, Motor selection 1:left 2:right 0:all
uint8_t is_MotorDirection, Motor steering 1:Forward 2:Reverse 0:stop
uint8_t is_MotorSpeed, Motor speed 0-250
void DIY_MotorControl_Plus(uint8_t is_MotorSelection, uint8_t is_MotorDirection, uint8_t is_MotorSpeed)
static boolean MotorControl = false;
if (func_mode == DIY_MotorControl) //Motor control mode
MotorControl = true;
if (is_MotorSelection == 1 || is_MotorSelection == 0) //Left motor
if (is_MotorDirection == 1) //Positive rotation
analogWrite(ENA, is_MotorSpeed);
else if (is_MotorDirection == 2) //Reverse
else if (is_MotorDirection == 0)
digitalWrite(ENA, LOW); //Turn off the motor enable pin
if (is_MotorSelection == 2 || is_MotorSelection == 0) //Right motor
analogWrite(ENB, is_MotorSpeed);
digitalWrite(ENB, LOW); //Turn off the motor enable pin
if (MotorControl == true)
N4:command
DIY mode:<Car control> APP control car
Time limited
void DIY_CarControl_Plus(uint8_t is_CarDirection, uint8_t is_CarSpeed, uint8_t is_Timer)
static boolean CarControl = false;
static boolean CarControl_TE = false; //Have time to spend
static boolean CarControl_return = false;
if (func_mode == DIY_CarControl) //Car Control Mode
CarControl = true;
if (is_Timer != 0) //Setting time cannot be empty
if ((millis() - DIY_CarControl_Millis) > (is_Timer * 1000)) //check the time
CarControl_TE = true;
if (CarControl_return == false)
CarControl_return = true;
if (CarControl_TE == false)
switch (is_CarDirection)
case 1: /*Left-Forward Motion Mode*/
left(false, is_CarSpeed);
case 2: /*Right-Forward Motion Mode*/
right(false, is_CarSpeed);
case 3: /*Sport mode forward*/
forward(false, is_CarSpeed);
case 4: /*Sport mode back*/
back(false, is_CarSpeed);
default:
if (CarControl == true)
CarControl = false;
DIY_CarControl_Millis = 0;
N40:command
No time limit
void DIY_CarControl_Plusxxx(uint8_t is_CarDirection, uint8_t is_CarSpeed)
if (func_mode == DIY_CarControlxxx) //Car Control Mode
CarControl = true;
default:
CarControl = false;
N5:command
DIY mode:Clear all features
void DIY_ClearAllFunctionsXXX(void)
if (func_mode == DIY_ClearAllFunctions)
mov_mode = STOP;
func_mode = IDLE;
/*DIY_MotorControl:Motor Control: Motor Speed、Motor Direction、Motor Time*/
DIY_MotorSelection = NULL;
DIY_MotorDirection = NULL;
DIY_MotorSpeed = NULL;
DIY_leftMotorControl_Millis = NULL;
DIY_rightMotorControl_Millis = NULL;
/*DIY_CarControl:Car Control:Car moving direction、Car Speed、Car moving time*/
DIY_CarDirection = NULL;
DIY_CarSpeed = NULL;
DIY_CarTimer = NULL;
DIY_CarControl_Millis = NULL;
void getDistance_xx(void)
DIY_Distance = getDistance(); //Ultrasonic measurement distance
/*****************************************************End@DIY**************************************************************************************/
void setup(void)
Serial.begin(9600); //initialization
servo.attach(PIN_Servo, 500, 2400); //500: 0 degree 2400: 180 degree
servo.write(90); //sets the servo position according to the 90(middle)
irrecv.enableIRIn(); //Enable infrared communication NEC
pinMode(ECHO_PIN, INPUT); //Ultrasonic module initialization
pinMode(TRIG_PIN, OUTPUT);
pinMode(IN1, OUTPUT); //Motor-driven port configuration
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(LineTeacking_Pin_Right, INPUT); //Infrared tracking module port configuration
pinMode(LineTeacking_Pin_Middle, INPUT);
pinMode(LineTeacking_Pin_Left, INPUT);
void loop(void)
bluetooth_mode(); //Bluetooth remote mode
irremote_mode(); //Infrared NEC remote control mode
line_teacking_mode(); //Line Teacking Mode
obstacles_avoidance_mode(); //Obstacles Avoidance Mode
if (Serial_mode == Serial_programming || Serial_mode == Serial_diy)
DIY_MotorControl_Plus(DIY_MotorSelection, DIY_MotorDirection, DIY_MotorSpeed); //Control motor steering
/* DIY mode:<Car control> APP control car*/
DIY_CarControl_Plus(DIY_CarDirection, DIY_CarSpeed, DIY_CarTimer); //Control the direction of the car<Time limited>
DIY_CarControl_Plusxxx(DIY_CarDirectionxxx, DIY_CarSpeedxxx); //Control the direction of the car<No Time limited>
DIY_ClearAllFunctionsXXX();
