Elegoo Smart Car v4.0 : code lost
Hi, I am extremely new to Arduino and lost all my code for the smart car which I don't have a sketch of. Does anyone know how to get the code back? My model has the TB6612 & MPU6050 Motor driver and gyro modules.
Thank you
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Hi. Welcome to the Forum!
I believe you can get the sketch back on Elegoo site : https://www.elegoo.com/pages/arduino-kits-support-files
I have tried this
It always gave me an error
I will send
This is not an error. This is the sketch that you should compile and upload to the board.
At the forum, sketches might be formatted, using this button:
 * @Author: ELEGOO
 * @Date: 2019-10-22 11:59:09
 * @LastEditTime: 2020-12-29 16:07:48
 * @LastEditors: Changhua
 * @Description: Smart Robot Car V4.0
 * @FilePath:
#include "DeviceDriverSet_xxx0.h"
//#include "PinChangeInt.h"
#include <avr/wdt.h>
#include <stdio.h>
static void
delay_xxx(uint16_t _ms)
  wdt_reset();
  for (unsigned long i = 0; i < _ms; i++)
    delay(1);
/*RBG LED*/
static uint32_t Color(uint8_t r, uint8_t g, uint8_t b)
  return (((uint32_t)r << 16) | ((uint32_t)g << 8) | b);
void DeviceDriverSet_RBGLED::DeviceDriverSet_RBGLED_xxx(uint16_t Duration, uint8_t Traversal_Number, CRGB colour)
  if (NUM_LEDS < Traversal_Number)
    Traversal_Number = NUM_LEDS;
  for (int Number = 0; Number < Traversal_Number; Number++)
    leds[Number] = colour;
    FastLED.show();
    delay_xxx(Duration);
void DeviceDriverSet_RBGLED::DeviceDriverSet_RBGLED_Init(uint8_t set_Brightness)
  FastLED.addLeds<NEOPIXEL, PIN_RBGLED>(leds, NUM_LEDS);
  FastLED.setBrightness(set_Brightness);
#if _Test_DeviceDriverSet
void DeviceDriverSet_RBGLED::DeviceDriverSet_RBGLED_Test(void)
  leds[0] = CRGB::White;
  FastLED.show();
  delay_xxx(50);
  leds[1] = CRGB::Red;
  FastLED.show();
  delay_xxx(50);
  DeviceDriverSet_RBGLED_xxx(50 /*Duration*/, 5 /*Traversal_Number*/, CRGB::Black);
#endif
void DeviceDriverSet_RBGLED::DeviceDriverSet_RBGLED_Color(uint8_t LED_s, uint8_t r, uint8_t g, uint8_t b)
  if (LED_s > NUM_LEDS)
    return;
  if (LED_s == NUM_LEDS)
    FastLED.showColor(Color(r, g, b));
    leds[LED_s] = Color(r, g, b);
  FastLED.show();
/*Key*/
uint8_t DeviceDriverSet_Key::keyValue = 0;
static void attachPinChangeInterrupt_GetKeyValue(void)
  DeviceDriverSet_Key Key;
  static uint32_t keyValue_time = 0;
  static uint8_t keyValue_temp = 0;
  if ((millis() - keyValue_time) > 500)
    keyValue_temp++;
    keyValue_time = millis();
    if (keyValue_temp > keyValue_Max)
      keyValue_temp = 0;
    Key.keyValue = keyValue_temp;
void DeviceDriverSet_Key::DeviceDriverSet_Key_Init(void)
  pinMode(PIN_Key, INPUT_PULLUP);
  //attachPinChangeInterrupt(PIN_Key, attachPinChangeInterrupt_GetKeyValue, FALLING);
  attachInterrupt(0, attachPinChangeInterrupt_GetKeyValue, FALLING);
void DeviceDriverSet_Key::DeviceDriverSet_Key_Test(void)
  Serial.println(DeviceDriverSet_Key::keyValue);
#endif
void DeviceDriverSet_Key::DeviceDriverSet_key_Get(uint8_t *get_keyValue)
  *get_keyValue = keyValue;
/*ITR20001 Detection*/
bool DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_Init(void)
  pinMode(PIN_ITR20001xxxL, INPUT);
  pinMode(PIN_ITR20001xxxM, INPUT);
  pinMode(PIN_ITR20001xxxR, INPUT);
  return false;
int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_L(void)
  return analogRead(PIN_ITR20001xxxL);
int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_M(void)
  return analogRead(PIN_ITR20001xxxM);
int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_R(void)
  return analogRead(PIN_ITR20001xxxR);
void DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_Test(void)
  Serial.print("\tL=");
  Serial.print(analogRead(PIN_ITR20001xxxL));
  Serial.print("\tM=");
  Serial.print(analogRead(PIN_ITR20001xxxM));
  Serial.print("\tR=");
  Serial.println(analogRead(PIN_ITR20001xxxR));
#endif
/*Voltage Detection*/
void DeviceDriverSet_Voltage::DeviceDriverSet_Voltage_Init(void)
  pinMode(PIN_Voltage, INPUT);
  //analogReference(INTERNAL);
float DeviceDriverSet_Voltage::DeviceDriverSet_Voltage_getAnalogue(void)
  //float Voltage = ((analogRead(PIN_Voltage) * 5.00 / 1024) * 7.67); //7.66666=((10 + 1.50) / 1.50)
  float Voltage = (analogRead(PIN_Voltage) * 0.0375);
  Voltage = Voltage + (Voltage * 0.08); //Compensation 8%
  //return (analogRead(PIN_Voltage) * 5.00 / 1024) * ((10 + 1.50) / 1.50); //Read voltage value
  return Voltage;
void DeviceDriverSet_Voltage::DeviceDriverSet_Voltage_Test(void)
  float Voltage = (analogRead(PIN_Voltage) * 0.0375); //7.66666=((10 + 1.50) / 1.50)
  //Serial.println(analogRead(PIN_Voltage) * 4.97 / 1024);
  Serial.println(Voltage);
#endif
/*Motor control*/
void DeviceDriverSet_Motor::DeviceDriverSet_Motor_Init(void)
  pinMode(PIN_Motor_PWMA, OUTPUT);
  pinMode(PIN_Motor_PWMB, OUTPUT);
  pinMode(PIN_Motor_AIN_1, OUTPUT);
  pinMode(PIN_Motor_BIN_1, OUTPUT);
  pinMode(PIN_Motor_STBY, OUTPUT);
void DeviceDriverSet_Motor::DeviceDriverSet_Motor_Test(void)
  //A...Right
  //B...Left
  digitalWrite(PIN_Motor_STBY, HIGH);
  digitalWrite(PIN_Motor_AIN_1, HIGH);
  analogWrite(PIN_Motor_PWMA, 100);
  digitalWrite(PIN_Motor_BIN_1, HIGH);
  analogWrite(PIN_Motor_PWMB, 100);
  delay_xxx(1000);
  digitalWrite(PIN_Motor_STBY, LOW);
  delay_xxx(1000);
  digitalWrite(PIN_Motor_AIN_1, LOW);
  digitalWrite(PIN_Motor_BIN_1, LOW);
  delay_xxx(1000);
#endif
 Motor_control:AB / movement direction and speed
void DeviceDriverSet_Motor::DeviceDriverSet_Motor_control(boolean direction_A, uint8_t speed_A, //Group A motor parameters
                                                          boolean direction_B, uint8_t speed_B, //Group B motor parameters
                                                          boolean controlED                     //AB enable setting (true)
                                                          )                                     //Motor control
  if (controlED == control_enable) //Enable motot control?
    { //A...Right
      switch (direction_A) //movement direction control
      case direction_just:
        analogWrite(PIN_Motor_PWMA, speed_A);
      case direction_back:
      case direction_void:
        analogWrite(PIN_Motor_PWMA, 0);
      default:
    { //B...Left
      switch (direction_B)
        analogWrite(PIN_Motor_PWMB, speed_B);
        analogWrite(PIN_Motor_PWMB, 0);
      default:
    return;
/*ULTRASONIC*/
//#include <NewPing.h>
// NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
void DeviceDriverSet_ULTRASONIC::DeviceDriverSet_ULTRASONIC_Init(void)
  pinMode(ECHO_PIN, INPUT); //Ultrasonic module initialization
  pinMode(TRIG_PIN, OUTPUT);
void DeviceDriverSet_ULTRASONIC::DeviceDriverSet_ULTRASONIC_Get(uint16_t *ULTRASONIC_Get /*out*/)
  unsigned int tempda_x = 0;
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  tempda_x = ((unsigned int)pulseIn(ECHO_PIN, HIGH) / 58);
  // *ULTRASONIC_Get = tempda_x;
  if (tempda_x > 150)
    *ULTRASONIC_Get = 150;
  // sonar.ping() / US_ROUNDTRIP_CM; // Send ping, get ping time in microseconds (uS).
void DeviceDriverSet_ULTRASONIC::DeviceDriverSet_ULTRASONIC_Test(void)
  unsigned int tempda = 0;
  tempda = ((unsigned int)pulseIn(ECHO_PIN, HIGH) / 58);
  // if (tempda_x > 50)
  //   tempda_x = 50;
  // // return tempda;
  // return tempda_x;
  Serial.print("ULTRASONIC=");
  Serial.print(tempda); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
  Serial.println("cm");
#endif
/*Servo*/
Servo myservo; // create servo object to control a servo
void DeviceDriverSet_Servo::DeviceDriverSet_Servo_Init(unsigned int Position_angle)
  myservo.attach(PIN_Servo_z, 500, 2400); //500: 0 degree  2400: 180 degree
  myservo.attach(PIN_Servo_z);
  myservo.write(Position_angle); //sets the servo position according to the 90(middle)
  delay_xxx(500);
  myservo.attach(PIN_Servo_y, 500, 2400); //500: 0 degree  2400: 180 degree
  myservo.attach(PIN_Servo_y);
  delay_xxx(500);
  myservo.detach();
void DeviceDriverSet_Servo::DeviceDriverSet_Servo_Test(void)
  for (;;)
    myservo.write(180);
    delay_xxx(500);
    myservo.write(0);
    delay_xxx(500);
  // for (uint8_t i = 0; i < 6; i++)
  //   myservo.write(30 * i);
  //   delay(500);
  // for (uint8_t i = 6; i > 0; i--)
  //   delay(500);
  // myservo.attach(PIN_Servo_y);
  //   delay(500);
  //   delay(500);
#endif
/*0.17sec/60degree(4.8v)*/
void DeviceDriverSet_Servo::DeviceDriverSet_Servo_control(unsigned int Position_angle)
  delay_xxx(450);
  myservo.detach();
//Servo motor control:Servo motor number and position angle
void DeviceDriverSet_Servo::DeviceDriverSet_Servo_controls(uint8_t Servo, unsigned int Position_angle)
  if (Servo == 1 || Servo == 3) //Servo_z
    if (Position_angle <= 1) //minimum angle control
      Position_angle = 1;
    if (Position_angle >= 17) //maximum angle control
      Position_angle = 17;
    myservo.write(10 * Position_angle);
    delay_xxx(500);
  if (Servo == 2 || Servo == 3) //Servo_y
    if (Position_angle <= 3) //minimum angle control
      Position_angle = 3;
    if (Position_angle >= 11) //maximum angle control
      Position_angle = 11;
    delay_xxx(500);
  myservo.detach();
/*IRrecv*/
IRrecv irrecv(RECV_PIN); //  Create an infrared receive drive object
decode_results results;  //  Create decoding object
void DeviceDriverSet_IRrecv::DeviceDriverSet_IRrecv_Init(void)
  irrecv.enableIRIn(); //Enable infrared communication NEC
bool DeviceDriverSet_IRrecv::DeviceDriverSet_IRrecv_Get(uint8_t *IRrecv_Get /*out*/)
  if (irrecv.decode(&results))
    IR_PreMillis = millis();
    switch (results.value)
    case /* constant-expression */ aRECV_upper:
    case /* constant-expression */ bRECV_upper:
      /* code */ *IRrecv_Get = 1;
    case /* constant-expression */ aRECV_lower:
    case /* constant-expression */ bRECV_lower:
      /* code */ *IRrecv_Get = 2;
    case /* constant-expression */ aRECV_Left:
    case /* constant-expression */ bRECV_Left:
      /* code */ *IRrecv_Get = 3;
    case /* constant-expression */ aRECV_right:
    case /* constant-expression */ bRECV_right:
      /* code */ *IRrecv_Get = 4;
    case /* constant-expression */ aRECV_ok:
    case /* constant-expression */ bRECV_ok:
      /* code */ *IRrecv_Get = 5;
    case /* constant-expression */ aRECV_1:
    case /* constant-expression */ bRECV_1:
      /* code */ *IRrecv_Get = 6;
    case /* constant-expression */ aRECV_2:
    case /* constant-expression */ bRECV_2:
      /* code */ *IRrecv_Get = 7;
    case /* constant-expression */ aRECV_3:
    case /* constant-expression */ bRECV_3:
      /* code */ *IRrecv_Get = 8;
    case /* constant-expression */ aRECV_4:
    case /* constant-expression */ bRECV_4:
      /* code */ *IRrecv_Get = 9;
    case /* constant-expression */ aRECV_5:
    case /* constant-expression */ bRECV_5:
      /* code */ *IRrecv_Get = 10;
    case /* constant-expression */ aRECV_6:
    case /* constant-expression */ bRECV_6:
      /* code */ *IRrecv_Get = 11;
    case /* constant-expression */ aRECV_7:
    case /* constant-expression */ bRECV_7:
      /* code */ *IRrecv_Get = 12;
    case /* constant-expression */ aRECV_8:
    case /* constant-expression */ bRECV_8:
      /* code */ *IRrecv_Get = 13;
    case /* constant-expression */ aRECV_9:
    case /* constant-expression */ bRECV_9:
      /* code */ *IRrecv_Get = 14;
    default:
      // *IRrecv_Get = 5;
      irrecv.resume();
      return false;
    irrecv.resume();
    return true;
    return false;
void DeviceDriverSet_IRrecv::DeviceDriverSet_IRrecv_Test(void)
    Serial.print("IRrecv_Test:");
    Serial.println(results.value);
    irrecv.resume();
#endif``
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In function 'void delay_xxx(uint16_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:19:5: error: 'delay' was not declared in this scope
     delay(1);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:19:5: note: suggested alternative: 'delay_xxx'
     delay(1);
     delay_xxx
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: At global scope:
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:27:6: error: 'DeviceDriverSet_RBGLED' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:27:102: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In function 'void DeviceDriverSet_RBGLED_xxx(uint16_t, uint8_t, int)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:29:7: error: 'NUM_LEDS' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:35:5: error: 'leds' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:35:5: note: suggested alternative: 'gets'
     gets
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:36:5: error: 'FastLED' was not declared in this scope
     FastLED.show();
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:40:6: error: 'DeviceDriverSet_RBGLED' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In function 'void DeviceDriverSet_RBGLED_Init(uint8_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:42:3: error: 'FastLED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:42:19: error: 'NEOPIXEL' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:42:29: error: 'PIN_RBGLED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:42:41: error: 'leds' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:42:41: note: suggested alternative: 'gets'
                                         gets
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:42:47: error: 'NUM_LEDS' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:58:6: error: 'DeviceDriverSet_RBGLED' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In function 'void DeviceDriverSet_RBGLED_Color(uint8_t, uint8_t, uint8_t, uint8_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:60:15: error: 'NUM_LEDS' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:62:16: error: 'NUM_LEDS' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:64:5: error: 'FastLED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:68:5: error: 'leds' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:68:5: note: suggested alternative: 'gets'
     gets
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:70:3: error: 'FastLED' was not declared in this scope
   FastLED.show();
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:74:30: error: 'uint8_t DeviceDriverSet_Key::keyValue' is not a static data member of 'class DeviceDriverSet_Key'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In function 'void attachPinChangeInterrupt_GetKeyValue()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:81:8: error: 'millis' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:89:9: error: 'class DeviceDriverSet_Key' has no member named 'keyValue'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'void DeviceDriverSet_Key::DeviceDriverSet_Key_Init()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:94:20: error: 'INPUT_PULLUP' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:94:3: error: 'pinMode' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:96:60: error: 'FALLING' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:96:3: error: 'attachInterrupt' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:106:72: error: no 'void DeviceDriverSet_Key::DeviceDriverSet_key_Get(uint8_t*)' member function declared in class 'DeviceDriverSet_Key'
In file included from C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:9:0:
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'bool DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_Init()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.h:48:26: error: 'A2' was not declared in this scope
 #define PIN_ITR20001xxxL A2
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:114:11: note: in expansion of macro 'PIN_ITR20001xxxL'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.h:48:26: note: suggested alternative: 'AS2'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:114:29: error: 'INPUT' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:114:3: error: 'pinMode' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.h:49:26: error: 'A1' was not declared in this scope
 #define PIN_ITR20001xxxM A1
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:115:11: note: in expansion of macro 'PIN_ITR20001xxxM'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.h:50:26: error: 'A0' was not declared in this scope
 #define PIN_ITR20001xxxR A0
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:116:11: note: in expansion of macro 'PIN_ITR20001xxxR'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_L()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:121:21: note: in expansion of macro 'PIN_ITR20001xxxL'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:121:10: error: 'analogRead' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_M()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:125:21: note: in expansion of macro 'PIN_ITR20001xxxM'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:125:10: error: 'analogRead' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_R()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:129:21: note: in expansion of macro 'PIN_ITR20001xxxR'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:129:10: error: 'analogRead' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'void DeviceDriverSet_Voltage::DeviceDriverSet_Voltage_Init()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.h:63:21: error: 'A3' was not declared in this scope
 #define PIN_Voltage A3
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:148:11: note: in expansion of macro 'PIN_Voltage'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:148:24: error: 'INPUT' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:148:3: error: 'pinMode' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'float DeviceDriverSet_Voltage::DeviceDriverSet_Voltage_getAnalogue()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:154:31: note: in expansion of macro 'PIN_Voltage'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:154:20: error: 'analogRead' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:171:60: error: no 'void DeviceDriverSet_Motor::DeviceDriverSet_Motor_Init()' member function declared in class 'DeviceDriverSet_Motor'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:208:59: error: variable or field 'DeviceDriverSet_Motor_control' declared void
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:208:59: error: 'boolean' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:208:59: note: suggested alternative: 'bool'
                                                           bool
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:208:88: error: expected primary-expression before 'speed_A'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:209:59: error: 'boolean' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:209:59: note: suggested alternative: 'bool'
                                                           bool
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:209:88: error: expected primary-expression before 'speed_B'
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:210:59: error: 'boolean' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:210:59: note: suggested alternative: 'bool'
                                                           bool
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'void DeviceDriverSet_ULTRASONIC::DeviceDriverSet_ULTRASONIC_Init()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:276:21: error: 'INPUT' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:276:3: error: 'pinMode' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:277:21: error: 'OUTPUT' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'void DeviceDriverSet_ULTRASONIC::DeviceDriverSet_ULTRASONIC_Get(uint16_t*)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:282:26: error: 'LOW' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:282:3: error: 'digitalWrite' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:283:3: error: 'delayMicroseconds' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:284:26: error: 'HIGH' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:284:26: note: suggested alternative: 'DISH'
                          DISH
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:287:29: error: 'pulseIn' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp: In member function 'bool DeviceDriverSet_IRrecv::DeviceDriverSet_IRrecv_Get(uint8_t*)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\DeviceDriverSet_xxx0.cpp:436:20: error: 'millis' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:26:1: error: 'DeviceDriverSet_RBGLED' does not name a type; did you mean 'DeviceDriverSet_IRrecv'?
 DeviceDriverSet_RBGLED AppRBG_LED;
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::ApplicationFunctionSet_Init()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:109:12: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_Init'; did you mean 'DeviceDriverSet_Motor'?
   AppMotor.DeviceDriverSet_Motor_Init();
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:112:3: error: 'AppRBG_LED' was not declared in this scope
   AppRBG_LED.DeviceDriverSet_RBGLED_Init(20);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In function 'void ApplicationFunctionSet_SmartRobotCarLinearMotionControl(SmartRobotCarMotionControl, uint8_t, uint8_t, uint8_t, uint8_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:159:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
     AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_void, /*speed_A*/ 0,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:191:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
     AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_just, /*speed_A*/ R,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:196:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
     AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_back, /*speed_A*/ L,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In function 'void ApplicationFunctionSet_SmartRobotCarMotionControl(SmartRobotCarMotionControl, uint8_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:247:16: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
       AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_just, /*speed_A*/ speed,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:261:16: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
       AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_back, /*speed_A*/ speed,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:274:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:280:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:286:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:292:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:298:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
     AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_just, /*speed_A*/ speed / 2,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:304:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
     AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_back, /*speed_A*/ speed / 2,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:310:14: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In function 'void CMD_Lighting(uint8_t, int8_t, uint8_t, uint8_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:386:5: error: 'AppRBG_LED' was not declared in this scope
     AppRBG_LED.DeviceDriverSet_RBGLED_Color(NUM_LEDS, is_LightingColorValue_R, is_LightingColorValue_G, is_LightingColorValue_B);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:386:45: error: 'NUM_LEDS' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::ApplicationFunctionSet_RGB()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:412:3: error: 'FastLED' was not declared in this scope
   FastLED.clear(true);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:427:7: error: 'AppRBG_LED' was not declared in this scope
       AppRBG_LED.DeviceDriverSet_RBGLED_xxx(0 /*Duration*/, 2 /*Traversal_Number*/, CRGB::Red);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:427:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:431:85: error: 'CRGB' has not been declared
       AppRBG_LED.DeviceDriverSet_RBGLED_xxx(0 /*Duration*/, 2 /*Traversal_Number*/, CRGB::Black);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:435:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:439:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:443:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:447:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:451:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:455:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:459:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:463:85: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:478:11: error: 'AppRBG_LED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:478:89: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:480:89: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:506:11: error: 'AppRBG_LED' was not declared in this scope
           AppRBG_LED.leds[0] = CRGB::Violet;
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:506:32: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:520:9: error: 'AppRBG_LED' was not declared in this scope
         AppRBG_LED.DeviceDriverSet_RBGLED_xxx(0 /*Duration*/, 2 /*Traversal_Number*/, CRGB::Green);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:520:87: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:526:9: error: 'AppRBG_LED' was not declared in this scope
         AppRBG_LED.DeviceDriverSet_RBGLED_xxx(0 /*Duration*/, 2 /*Traversal_Number*/, CRGB::Yellow);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:526:87: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:532:9: error: 'AppRBG_LED' was not declared in this scope
         AppRBG_LED.DeviceDriverSet_RBGLED_xxx(0 /*Duration*/, 2 /*Traversal_Number*/, CRGB::Blue);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:532:87: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:538:9: error: 'AppRBG_LED' was not declared in this scope
         AppRBG_LED.DeviceDriverSet_RBGLED_xxx(0 /*Duration*/, 2 /*Traversal_Number*/, CRGB::Violet);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:538:87: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::CMD_MotorControl_xxx0(uint8_t, uint8_t, uint8_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:957:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
           AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_just, /*speed_A*/ is_MotorSpeed_A,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:963:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
           AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_back, /*speed_A*/ is_MotorSpeed_A,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:978:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:984:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:999:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
           AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_void, /*speed_A*/ is_MotorSpeed_A,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1005:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::CMD_MotorControl_xxx0()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1052:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1058:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1073:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1079:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1094:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1100:20: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::CMD_MotorControlSpeed_xxx0(uint8_t, uint8_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1299:16: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
       AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_just, /*speed_A*/ is_Speed_L,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::CMD_MotorControlSpeed_xxx0()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1324:16: error: 'class DeviceDriverSet_Motor' has no member named 'DeviceDriverSet_Motor_control'; did you mean 'DeviceDriverSet_Motor'?
       AppMotor.DeviceDriverSet_Motor_control(/*direction_A*/ direction_just, /*speed_A*/ CMD_is_MotorSpeed_L,
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::CMD_LightingControlTimeLimit_xxx0(uint8_t, uint8_t, uint8_t, uint8_t, uint32_t)':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1370:9: error: 'FastLED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::CMD_LightingControlTimeLimit_xxx0()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1417:9: error: 'FastLED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::CMD_ClearAllFunctions_xxx0()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1496:5: error: 'FastLED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1497:5: error: 'AppRBG_LED' was not declared in this scope
     AppRBG_LED.DeviceDriverSet_RBGLED_xxx(0 /*Duration*/, NUM_LEDS /*Traversal_Number*/, CRGB::Black);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1497:59: error: 'NUM_LEDS' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1497:90: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1505:5: error: 'FastLED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1506:5: error: 'AppRBG_LED' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1506:59: error: 'NUM_LEDS' was not declared in this scope
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1506:90: error: 'CRGB' has not been declared
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::ApplicationFunctionSet_KeyCommand()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1628:10: error: 'class DeviceDriverSet_Key' has no member named 'DeviceDriverSet_key_Get'; did you mean 'DeviceDriverSet_Key_Init'?
   AppKey.DeviceDriverSet_key_Get(&get_keyValue);
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp: In member function 'void ApplicationFunctionSet::ApplicationFunctionSet_SerialPortDataAnalysis()':
C:\Users\nagor\Downloads\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\ELEGOO Smart Robot Car Kit V4.0 2022.10.26\02 Manual & Main Code & APP\02 Main Program   (Arduino UNO)\TB6612 & MPU6050\SmartRobotCarV4.0_V1_20220303\ApplicationFunctionSet_xxx0.cpp:1962:9: error: 'FastLED' was not declared in this scope
         FastLED.setBrightness(CMD_is_FastLED_setBrightness);
exit status 1
Compilation error: 'delay' was not declared in this scope``
ApplicationFunctionSet_xxx0.cpp (67.8 KB)
ApplicationFunctionSet_xxx0.h (4.5 KB)
ArduinoJson-v6.11.1.h (172.7 KB)
Description.txt (687 Bytes)
DeviceDriverSet_xxx0.cpp (14.0 KB)
DeviceDriverSet_xxx0.h (4.2 KB)
I2Cdev.cpp (55.1 KB)
I2Cdev.h (6.8 KB)
IRremote.cpp (31.0 KB)
IRremote.h (4.1 KB)
IRremoteInt.h (14.6 KB)
MPU6050.cpp (45.2 KB)
MPU6050.h (36.3 KB)
MPU6050_getdata.cpp (2.3 KB)
MPU6050_getdata.h (692 Bytes)
SmartRobotCarV4.0_V1_20220303.ino (1.5 KB)
This code is not the same of the one in post #8. Upload this one to your board.
it doesnt work
