Elegoo Tumbller: basic questions
Hi all,
I just assembled the tumbller and everything works great.
Now I wanted to try program it and possibly expand it in the future.
Since I'm going to learn this platform with my kid, who's the actual owner and assmbler of the robot, I want to go through mblock.
Here is the board specs: Kit per Robot Tumbller
Now the first questions.
  • The bot came with preflashed instructions allowing the bot to be controlled both via button and Bluetooth. If I start playing with mblock to run commands on the bot, will I loose the preflashed instructions or I can run commands without flashing?
  • If I want to expand it for voice control it and add a camera, what do I need and what do I have to check?
I just got a tumbller with a preloaded firmware offering various functions.
It can be controller with a physical button which has 4 operating modes and can be also controlled with elegoo remote app which has a preprogrammed remote pad and a customizable one where you can set your own commands to move the bot or let leds switch on/off.
Now I wanted to dig it.
AFAIK if I want to try my code I'll loose the preloaded functions.
But today I found the bluetooth arduino controller: if it's connecting successfully and starts working, will I lose the preloaded firmware when launching my commands?
And what about mblock ide: it can also connect via BT
I connected to the bot with ./G4DUDE configured like this:
  • config.ini : put the correct port detected by arduino IDE
  • programmer type : arduino
  • chip type : ATMega328p
/usr/bin/avrdude -pm328p -carduino -P/dev/ttyACM0 -t
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude> part
part
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
avrdude> sig
sig
avrdude> d lfuse
d lfuse
0000 00 |. |
avrdude> d hfuse
d hfuse
0000 00 |. |
avrdude> d efuse
d efuse
0000 00 |. |
avrdude> quit
quit
avrdude done. Thank you.
I can then read the chip and backup the code
