ELEGOO UNO R3 2.8 with UTFT.h library
Hello all,
I’m trying to build a project I found online but i’m facing a problem.
Project i’m trying to build: Replica of Flappy Bird for Arduino
I’m using ELEGOO UNO R3 2.8 Inches TFT Touch Screen link with arduino UNO
The problem is that the screen uses different libraries to work and I’ve looked online so much to find a way to know the right wiring for the shield on the UTFT library.
In other words I need help figuring out what is the right code to initialize the screen
UTFT myGLCD(ITDB28_V2,A5,A4,A3,A2);
What are the right pin numbers and screen model in order for this screen to run on this code without modifying the libraries?
I’ve tried to replace the UTFT with <MCUFRIEND_kbv.h> library but the problem is that a lot of the functions inside those libraries are different, so I’d need to re write every function.
Hope I made my problem clear,
Thank you,
