Elegoo UNO R3 Not detected - Windows 10
Dear all,
I have a problem trying to run a code to use a DHT11 to measure temperature.
I have installed Arduino but Port selection is grayed, so I can not select any port.
In device manager I do not see any Unknow Device, and there is no sound when I plug the arduino to the computer. It just does nothing.
Any ideas? I have tried to install drivers but It does not solve my problem.
Thanks in advance.
Are you using USB 2.0 or 3.0 ?
USB 3.0 has been seen to cause issues and 2.0 is often the cure.
Or in some instances a powered USB 2.0 hub.
Thank you very much for your answer.
I am using USB 3.0, unfortunately in that computer I have not USB 2.0. However, giving your post, I am going to give it a try in a different computer with W10 and USB 2.0.
Some more help in the links below.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
