eletronic web door lock
I'm doing a electrical door look and i want to register users by web but i don't know how to retrieve the information's from the html form and i don't know how to call another form. I want to do it without using PHP.
i'm doing this for my final work to graduate on university, the part with the door look and the numerical keypad i already did.
when finished i can post all the code if someone is interested :wink:
thanks by the help.
Simple server test code that will print what it receives to the serial monitor.
//zoomkat 4-1-12
//simple button GET for servo and pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html, or use ' instead of "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  myservo.write(90); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  //enable serial data print
  Serial.println("server servo/pin 5 test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println("Content-Type: text/html");
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          client.println("<a href=\"/?on\">ON</a>");
          client.println("<a href=\"/?off\">OFF</a>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            myservo.write(40);
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            myservo.write(140);
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
I will need to use POST to retrieve the data it will be the same way ?
guimas:
No, it will be different. Below is some server POST code.
A simple web server using an Arduino Wiznet Ethernet shield.
For Arduino IDE V1.0 only. Previous IDE versions require mods to this code.
Original code created 18 Dec 2009
 by David A. Mellis
 modified 4 Sep 2010
 by Tom Igoe
 modified 18 Jan 2012
 by Tim Dicus
#include <SPI.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
IPAddress ip( 192,168,1,102 );
IPAddress gateway( 192,168,1,1 );
IPAddress subnet( 255,255,255,0 );
//IPAddress dns( 192,168,1,1 );
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
  // set SPI SS pins on w5100 and SD
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  // start the SD interface here if you want.
  // Add the SD.h library above
  // SD.begin(4);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip, dns, gateway, subnet);
  // disable w5100 SPI so SD SPI can work with it
  delay(2000);
  server.begin();
  Serial.println("setup finished");
  // listen for incoming clients
  if (client) {
    Serial.println("Client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
      while(client.available()) {
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
// Here is where the POST data is.
             Serial.write(client.read());
          Serial.println("Sending response");
          // send a standard http response header
          client.println("HTTP/1.0 200 OK");
          client.println();
          client.println("<HTML><BODY>TEST OK!");
//form added to send data from browser and view received data in serial monitor
client.println("<FORM ACTION=\"http://192.168.1.102:84\" METHOD=\"post\">");
client.println("Name: <INPUT TYPE=\"TEXT\" NAME=\"Name\" VALUE=\"\" SIZE=\"25\" MAXLENGTH=\"50\">
client.println("Email: <INPUT TYPE=\"TEXT\" NAME=\"Email\" VALUE=\"\" SIZE=\"25\" MAXLENGTH=\"50\">
client.println("<INPUT TYPE=\"SUBMIT\" NAME=\"submit\" VALUE=\"Sign Me Up!\">");
client.println("</FORM>");
client.println("
          client.stop();
        else if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    Serial.println("Disconnected");
