Hello, I am trying to use the ELMduino.h library to read data from the car's ECU, on a 16x2 LCD screen, but strange texts appear on the screen.
This is my code:
//Import i2C LCD libraries
#include "BluetoothSerial.h"
#include "ELMduino.h"
// set the LCD number of columns and rows
int lcdColumns = 16;
int lcdRows = 2;
// set LCD address, number of columns and rows
// if you don't know your display address, run an I2C scanner sketch
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows);
BluetoothSerial SerialBT;
#define ELM_PORT SerialBT
#define DEBUG_PORT Serial
ELM327 myELM327;
uint32_t rpm = 0;
#if LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
#endif
// initialize LCD
lcd.init();
// turn on LCD backlight
lcd.backlight();
DEBUG_PORT.begin(115200);
//SerialBT.setPin("1234");
ELM_PORT.begin("ArduHUD", true);
if (!ELM_PORT.connect("OBDII"))
DEBUG_PORT.println("Couldn't connect to OBD scanner - Phase 1");
while(1);
if (!myELM327.begin(ELM_PORT, true, 2000))
Serial.println("Couldn't connect to OBD scanner - Phase 2");
while (1);
Serial.println("Connected to ELM327");
void loop(){
float tempRPM = myELM327.rpm();
if (myELM327.nb_rx_state == ELM_SUCCESS)
rpm = (uint32_t)tempRPM;
// set cursor to first column, first row
lcd.setCursor(0, 0);
lcd.print("RPM: " + rpm); Serial.println(rpm);
else if (myELM327.nb_rx_state != ELM_GETTING_MSG)
myELM327.printError();
I don't know what I'm doing wrong, in the following line to load the data on the screen:
Thnks for help
