Else has an if but compiler says it doesn't
Hi.
I was trying to write some short code in my free time , but I faced a weird problem .
/* Made by Arman on  23 / APRIL / 2015
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // LCD is declared
  lcd.init();   // LCD's initialization
  lcd.backlight(); // backlight
  lcd.clear(); // clear shit
  if (random(2,5) == 3); {
    lcd.print("It will ");
  else {
    lcd.print("It won't ");
  delay(1000); //makes things more stressful
  setCursor(0,1);
  // writes the first line
  if (random(10,27) == 13); {
    lcd.print("stop happening.");
  else {
    lcd.print("happen.");
 // writes the second line
void loop () {
Then a weird error appears (a bunch of them) :
sketch_apr23a.ino: In function 'void setup()':
sketch_apr23a:18: error: 'else' without a previous 'if'
sketch_apr23a:22: error: 'setCursor' was not declared in this scope
sketch_apr23a:24: error: expected `;' before 'if'
sketch_apr23a:27: error: 'else' without a previous 'if'
Else without previous if ?
I know I should put
If - else If - else
but I don't need else If .
setCursor wasn't declared ?
I tried setCursor(0,1);
and setCursor(0,1)
(without semicolon) but no difference .
expected ; before if ?
Where did I miss THAT ?
Thanks in advance .
The compiler is correct, the else is effectively in the middle of nowhere:
if (random(2,5) == 3)[glow=red,2,300][tt][b][size=x-large];[/size][/b][/glow] {
else {
}[/tt]
the same mistake here
Your if's have an empty statement as the then-part. The empty statement is ";".
If takes either a statement or a block, you gave an empty statement so the brace
starts a new block unrelated to the if.
Arman5592:
Obviously.
Here is your code with slightly different formatting and comments added:
if (random(2,5) == 3); // if (random(2,5) == 3) ==> do nothing, if-statement finished
{                                // begin a code block
}                                // end a code block
else                            // else without prevous if!
Your title suggests that you think the compiler is making a mistake.
NEVER waste time worrying about compiler bugs. They are only a little more common than hens' teeth.
ALWAYS assume the compiler is correct and the error is in your own code.
...R
Robin2:
...R
Robin2:
...R
I know this algorithm wouldn't fail but I didn't know what was wrong .
Thanks everyone , problem is solved .
I also missed lcd. before setCursor .
This is the working one :
#include <Wire.h>
  if (random(2,5) == 3) {
  else {
  lcd.setCursor(0,1);
  if (random(10,27) == 13) {
  else {
void loop () {
