else if multiple criteria
Hi all,
I have a sketch with a temp sensor and sending signal to leds and relais whenever the temp hits a certain value.
So the main point is that when the temp is above 30 the red led gets a signal and relais turns off, when the temp is below 23 the yellow led gets a signal and relais turns on and when in between the green led gets signal and relais turns off.
What i want to do now is add another which is when temp goes below 15 sending red led signal and turn relais off. Now how to add a fourth criterium to the formula?
// Program: DS18B20 temperature sensor
#include <OneWire.h>
#include <DallasTemperature.h>
#include <LiquidCrystal.h>
#define RELAY1  A1  // Relay heating
#define RELAY2  A2  // Relay heating
int green = 8; // green LED warm
int yellow = 9; // yellow LED cold
int red = 10; // red LED alarm
const int analogInPin = A0;
int sensorValue = 1;
unsigned long int avgValue;
float b;
int buf[10],temp;
// DS18B20 signal pin port
#define ONE_WIRE_BUS 3
// Defines an instance of oneWire to communicate with the sensor
OneWire oneWire(ONE_WIRE_BUS);
// Stores minimum and maximum temperatures
float tempMin = 999;
float tempMax = 0;
DallasTemperature sensors(&oneWire);
DeviceAddress sensor1;
// Initializes the LCD
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
void setup(void)
  sensors.begin();
  // Finds and displays sensor addresses
  Serial.println("Locating DS18B20 sensors...");
  Serial.print("Were found ");
  Serial.print(sensors.getDeviceCount(), DEC);
  Serial.println(" sensors.");
  if (!sensors.getAddress(sensor1, 0))
     Serial.println("Sensors not found !");
  // Shows the address of the sensor found on the bus
  Serial.print("Sensor address: ");
  show_sensor_address (sensor1);
  lcd.begin(20, 4);
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
void show_sensor_address(DeviceAddress deviceAddress)
  for (uint8_t i = 0; i < 8; i++)
    // Add zeros if necessary
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
  // Read sensor information
  sensors.requestTemperatures();
  float tempC = sensors.getTempC(sensor1);
  // Updates minimum and maximum temperatures
  if (tempC < tempMin)
    tempMin = tempC;
  if (tempC > tempMax)
    tempMax = tempC;
  // Shows data on the serial monitor
  Serial.print("Temp C: ");
  Serial.print(tempC);
  Serial.print(" Min : ");
  Serial.print(tempMin);
  Serial.print(" Max : ");
  Serial.println(tempMax);
  // Shows Temp data on the LCD
    delay(3000);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Temp.:       ");
  //Degree symbol
  lcd.write(223);
  lcd.print("C");
  lcd.setCursor(7,0);
  lcd.print(tempC);
  lcd.setCursor(0,1);
  lcd.print("L: ");
  lcd.setCursor(3,1);
  lcd.print(tempMin,2);
  lcd.setCursor(12,1);
  lcd.print("H: ");
  lcd.setCursor(15,1);
  lcd.print(tempMax,2);
   // read the input on analog pin 0:
 int sensorValue = analogRead(A0);
 // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
 float voltage = sensorValue * (5.0 / 1023.0);
 // print out the value you read:
 Serial.println(voltage);
  for(int i=0;i<10;i++)
  buf[i]=analogRead(analogInPin);
  delay(10);
 for(int i=0;i<9;i++)
  for(int j=i+1;j<10;j++)
   if(buf[i]>buf[j])
    temp=buf[i];
    buf[i]=buf[j];
    buf[j]=temp;
 avgValue=0;
 for(int i=2;i<8;i++)
 avgValue+=buf[i];
 float pHVol=(float)avgValue*5.0/1024/6;
 float phValue = -5.70 * pHVol + 21.34;
 Serial.print("sensor = ");
 Serial.println(phValue);
 delay(20);
   // Shows pH data on the LCD
  lcd.setCursor(0,3);
  lcd.print("pH: ");
  lcd.setCursor(4,3);
  lcd.print(phValue,2);
  float temperature = sensors.getTempCByIndex(0);
    if(temperature > 30)
digitalWrite(green,LOW);
digitalWrite(yellow,LOW);
digitalWrite(red,HIGH);
      lcd.setCursor(1,2);
      lcd.print("ALARM ALARM ALARM");
digitalWrite(RELAY1,1);
digitalWrite(RELAY2,1);
    else if(temperature > 23)
digitalWrite(green,HIGH);
digitalWrite(red,LOW);
      lcd.setCursor(0,2);
      lcd.print("Heating off");
else {
digitalWrite(yellow,HIGH);
      lcd.setCursor(0,2);
      lcd.print("Heating on");
digitalWrite(RELAY1,0);
digitalWrite(RELAY2,0);
A second else/if clause would seem to be the obvious answer
ah yes you are right and it works :smiley:
