Can you please explain the difference between using Else if vs. just using an If and a second If??
If the choice is binary (true vs false), using a second if just makes you look stupid.
No-one wants to look stupid.
Using a second 'if' can waste time. If the first 'if x' was true, we know that x is true. Testing it again with 'if not x' is now redundant, so it's a waste of processor time.
The ‘else if()’ line is not executed when the ‘if()’ line is true.
Look at switch/case for a similar solution when simple integer comparisons are needed.
