When compiling, I get the error: "In function 'void loop()' " followed by " 'else' without a previous 'if' ". I've searched the web and arduino's old and new forums for similar posts, and the others have been solved by removing semicolons that end the initial if statement. I don't think this is my issue, and when I change 'else' to another 'if' statement, the code compiles just fine. The syntax error is probably right in front of my eyes, but does anyone have any thoughts?
Thanks. See the code excerpt below:
if(relayVal==1)
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
delay(5000); // delays 5s before moving to start position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
