ELSE WITHOUT A PREVIOUS 'IF'
Hi. Anyone knows what this means or how could I change it so it could work. I void loop() is it that I need more than one huge bracket? Thanks!
const int LED_BUILTIN = 13;
const int pin12 = 12;
int val = 0;
pinMode(LED_BUILTIN,OUTPUT);
pinMode(pin12,OUTPUT);
if(LED_BUILTIN == LOW);
digitalWrite(LED_BUILTIN,HIGH);
else if(LED_BUILTIN > val);
digitalWrite(LED_BUILTIN,LOW);
digitalWrite(pin12,HIGH);
digitalWrite(pin12,LOW);
Arduino: 1.6.5 (Mac OS X), Board: "Arduino/Genuino Uno"
In file included from /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Arduino.h:249:0, from sketch_oct26a.ino:1: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard/pins_arduino.h:47:21: error: expected unqualified-id before numeric constant
define LED_BUILTIN 13
^ sketch_oct26a.ino:1:11: note: in expansion of macro 'LED_BUILTIN' sketch_oct26a.ino: In function 'void loop()': sketch_oct26a:13: error: 'else' without a previous 'if' sketch_oct26a:15: error: 'else' without a previous 'if' 'else' without a previous 'if'
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
Your loops are not correct in the first place.
Also please use code tags.
[tag] Code goes here [/tag] - replace the word tag with code. Edit your post to correct this.
Example if:
void loop(){ // squiggle for start of loop code
if (a > b) { " if a is bigger than B...do this" }     // note the two enclosing squiggles.
else { "otherwise do this" }    // note the two enclosing squiggles.
} //squiggle for end of loop code
When formatted as standard...it should look like this:
if (a > b) {
    print("A is bigger than B");
else {
    print("A is not bigger than B");
You shouldn't end your if statements with a ";".
No, it should look like this:
if (a > b)
Remove this line. LED_BUILTIN is a predefined constant.
hi
this compile
#define LED_BUILTIN 13;
int pin12 = 12;
int val = 0;
pinMode(pin12, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
if(LED_BUILTIN == LOW){
else if(LED_BUILTIN > val){
else {
PaulS: No, it should look like this:
if (a > b)
Oooops sorry. The little python I know crept in there!
a55830: hi
this compile
int pin12 = 12;
int val = 0;
{ pinMode(pin12, OUTPUT); pinMode(LED_BUILTIN, OUTPUT); }
{   if(LED_BUILTIN == LOW){  digitalWrite(LED_BUILTIN,HIGH);  }   else if(LED_BUILTIN > val){  digitalWrite(LED_BUILTIN,LOW);  } else { digitalWrite(pin12,HIGH); digitalWrite(pin12,LOW);
You don't need that either. This line is already in "pins.arduino.h":
It is predefined. You do not need to define it!
A #define has no ";"
