'else' without a previous 'if'
Thanks for the help :). I am still very new to the language.
please help. I am trying to make a variable speed fan with a redboard but the code keeps coming back as 'else' without a previous 'if' error code. code below. help would be appreciated.
if (val == 1);{
digitalWrite(5, HIGH);
digitalWrite(12, LOW);
digitalWrite(16, LOW);
else if (val == 2)
digitalWrite(12, HIGH);
else if (val == 3)
digitalWrite(16, HIGH);
digitalWrite (5, LOW);
digitalWrite (12, LOW);
digitalWrite (16, LOW);
you have brackets and colons in the wrong place! I would advise you touch up on the syntax for the language... :wink:
 if (val == 1){
  else if (val == 2){
  else if (val == 3){
  else{
hope that helps...
 if (val == 1);
Remove the semicolon
It is the only code that is executed conditionally when the test returns true
A semicolon by itself is a null statement, rarely useful, although it can be used like this:
  if (condition)
    ;  // do nothing
    do_something() ;
Which is a way of avoiding inverting the condition, its perfectly reasonable to do this instead:
  if (!(condition))
    do_something() ;
