'else' without previous 'if ' ---- I am getting this error, suggestions pls
const int xpin = A0;
const int ypin = A1;
const int zpin = A2;
const int led1 = 5;
const int led2 = 6;
const int led3 = 7;
  pinMode(led1,OUTPUT);
  pinMode(led2,OUTPUT);
  pinMode(led3,OUTPUT);
unsigned int zaxis,yaxis,xaxis;
  xaxis = analogRead(xpin);
  yaxis = analogRead(ypin);
  zaxis = analogRead(zpin);
  if (xaxis > 390);
   digitalWrite (led1,HIGH);
   digitalWrite (led1,LOW);
  if (yaxis > 390);
   digitalWrite (led2,HIGH);
   digitalWrite (led2,LOW);
  if (zaxis > 390);
   digitalWrite (led3,HIGH);
   digitalWrite (led3,LOW);
Oops.
Every single "if"
Remove the semicolons from your if statements.
C
Welcome to the forum
Delete the semicolons on the end of the if statements. They should not be there
This worked
Do you understand why ?
Many Thanks
With the code as it looks, there is no reason for these variables to have global scope.
Yea, I removed semicolons from all "if" statements
Ah, okay
But do you understand what the problem was and why removing the semicolons fixed it ?
Can u pls explain ?
The structure of an if/else is
if (this is true)
  //execute this code
  //execute this code
When you put a semicolon on the end of an if test it is the code that is executed when the test returns true so the code effectively becomes
if (this is true)
  //execute the semicolon
  //execute this code
  //execute this code
Note how there are now 2 code blocks after the if before the else hence the "else without previous if error
Ahh.. Got it Now!!
Many thanks for this explanation
It is quite a common error, hence the quick responses here
At least when you do it with if/else you get an explicit error when compiling. When you do it with a simple if (or while) the problem can be more difficult to track down because instead of an error the code does not do what you want or expect
Yea, Alright
