EM-18 Does Not Read Card
Hello everyone,
I am studying in field of RFID now. But i have a problem. I am using EM-18 module as rf id module. I connected pins in this way; VCC to 3.3 V, SEL to 5V, GND to GND, TX to RX. I cant see any output in serial monitor. You can see my Arduino Stech and connection schema is below. Why am i having such a problem?
Thank you.
// VARIABLE DECLARATION
char input[12];
int count = 0;
// SETUP FUNCTION
	Serial.begin(9600);   // START SERIAL AT BAUD RATE OF 9600 BITS/SEC
// LOOP FUNCTION
	if(Serial.available())   // CHECK FOR AVAILABILITY OF SERIAL DATA
		count = 0; 			// Reset the counter to zero
		/* Keep reading Byte by Byte from the Buffer till the RFID Reader Buffer is	empty
		   or till 12 Bytes (the ID size of our Tag) is read */
		while(Serial.available() && count < 12)
			input[count] = Serial.read(); // Read 1 Byte of data and store it in the input[] variable
			count++; 					// increment counter
			delay(5);
     // PRINTING RFID TAG
    for(int i=0;i<12;i++)
    Serial.print(input[i]);
Oops. Hopefully, the module survived.
jremington:
Why? Is it wrong?
Did you not realize that the module runs on 5V?
It is always a good idea to study and double check the data sheet before wiring and applying power.
I connect to VCC to 5V but again it doesn’t work. Help me please.
You may have destroyed the module by wiring it incorrectly in the first place.
Sorry, but keep in mind that we all make those mistakes.
