Hi guys, i´m trying to get an email altert to work but i can´t, the only thing that works fine is the temperature reading.
I have the following sketch, and when it gets compiled it returns a few errors:
28:29: warning: unused parameter 'subject' [-Wunused-parameter]
void sendEmail(char subject[], char message1[], char message2[], float temp) {
In function 'void loop()':
87:70: warning: integer overflow in expression [-Woverflow]
if (tempC >= HighThreshold && (millis()>(lastMessage+(emailInterval*1000)))) {
93:74: warning: integer overflow in expression [-Woverflow]
else if (tempC <= LowThreshold && (millis()>(lastMessage+(emailInterval*1000)))) {
My code is:
#include <Ethernet.h>
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define time 1000
#define ONE_WIRE_BUS 3
char message1[35], message2[35];
char subject[] = "ARDUINO TEMPERATURE ALERT""\0";
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer = { 0x28 ,0xFF ,0x63, 0x10, 0x00, 0x17, 0x04, 0xCC };
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xF7, 0x38 };
EthernetClient client;
void sendEmail(char subject[], char message1[], char message2[]) {
Serial.println("connecting...");
if (client.connect(server) {
Serial.println("connected");
client.println("AUTH LOGIN"); delay(time);
client.println("MAIL FROM:<sender@domain.com>"); delay(time);
client.println("RCPT TO:<recipient@domain.com>"); delay(time);
client.println("From: < sender@domain.com >"); delay(time);
client.println("to: < recipient@domain.com >"); delay(time);
client.print("SUBJECT: ");
client.println("subject"); delay(time);
client.println(); delay(time);
client.println(message1); delay(time);
client.println(message2); delay(time);
client.print("Temperature: ");
client.println(temp); delay(time);
client.println("."); delay(time);
Serial.println("Email sent."); delay(time);
Serial.println(".");
void checkEmail() {
while (client.available()) {
char = client.read();
Serial.print(c);
if (!client.connected()) {
client.();
void getTemperature(DeviceAddress deviceAddress) {
tempC = sensors.getTempC(deviceAddress);
tempF = DallasTemperature::toFahrenheit(tempC);
lastMessage = 0;
Ethernet.begin
sensors.begin(address);
sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
sensors.requestTemperatures();
getTemperature(address);
Serial.println(tempC);
delay(2500);
Serial.println("High Threshold Exceeded");
char message1[] = "Temperature Sensor\0";
char message2[] = "High Threshold Exceeded\0";
sendEmail(subject, message1, message2, tempC);
Serial.println("Low Threshold Exceeded");
char message2[] = "Low Threshold Exceeded\0";
Any toughts on how to fix this ?
Thanks
