email when motion detected
Ive got 2 scketches and I want to combine these. Ive tested them seperated and the work. Now I try to combine them. Ive uploaded thes sketch to my arduino but I think theres a mistake in de 'sendEmail' function. I can`t figure out what it is. I just started with my Arduinoproject. Can someone help me?
#include <SPI.h>
#include <Ethernet.h>
// my network settings
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { xxx, 168, 1, xxx};
byte gateway[] = { 192, xxx, 1, 254 };
byte subnet[] = { 255, 255, 255, 0 };
// my own SP smtp email server
byte server[] = { 194, 134, 41, 21 };
Client client(server,25);
const unsigned int PIR_INPUT_PIN = 2;
const unsigned int BAUD_RATE = 9600;
class PassiveInfraredSensor { // <label id="code.ethernet.pir_class"/>
  int _input_pin;
  public:
  PassiveInfraredSensor(const int input_pin)
    _input_pin = input_pin;
    pinMode(_input_pin, INPUT);
  const bool motion_detected() const
    return digitalRead(_input_pin) == HIGH;
PassiveInfraredSensor pir(PIR_INPUT_PIN);
  delay(10);
  Ethernet.begin(mac, ip, gateway, subnet);
  Serial.println("Ready");
  if (pir.motion_detected()) {
    Serial.println("Motion detected");
	delay(5000);// here you will need to determine how often you want to send this alert
    	// that will be up to you, but not 5 times a second!!
    if(sendEmail()) Serial.println("Email sent");
    else Serial.println("Email failed");
    Serial.println("No motion detected");
  delay(200);
sendEmail()
  byte inChar;
  inChar = Serial.read();
  if(inChar == 'e')
byte sendEmail()
  byte thisByte = 0;
  byte respCode;
  if (client.connect()) {
    Serial.println("connected");
    Serial.println("connection failed");
    return 0;
  while(!client.available()) delay(1);
  respCode = client.peek();
  while(client.available())
    thisByte = client.read();
    Serial.print(thisByte);
  if(respCode >= '4')
    efail();
    return 0;
// replace with your public ip
  client.write("helo 83.117.xxx.134\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
// replace with a valid from address
  client.write("MAIL From: xxx@online.nl>\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
// Replace with the recipient address
  client.write("RCPT To: <xxxxx@hotmail.com>\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
  client.write("DATA\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
// Replace with the recipient address as above
  client.write("To: fagio2000 <xxx@hotmail.com>\r\n");
// Replace with the sender address above
  client.write("From: Arduino <xxx@online.nl>\r\n");
  client.write("Subject: bericht van uw Arduino\r\n");
  client.write("Dit is de tekst die in de email komt te staan.\r\n");
  client.write(".\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
  client.write("QUIT\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
  client.stop();
  Serial.println("disconnected");
  return 1;
void efail()
  byte thisByte = 0;
  client.stop();
sendEmail()
  byte inChar;
  if(inChar == 'e')
Functions MUST have a return type defined. The number of { and the number of } MUST match. You've tried to violate both of these rules.
The number of { and } I will check. But what do you mean with return type? What is a return type of my "sendEmail' function? Do you mean I have to fill in some parameters?
This is the return type I used.
byte sendEmail()
   // email send code here.
The return type is a byte. That allows you to return the pass/fail to the loop().
return 0; // fail
return 1; //pass
That is what makes this work:
I see I used
two times:
in 'void loop' and in the function 'sendEmail' is this correct? Or should I delete it in the email function and start the emailfunction with:
byte sendEmail()
 return 0; // fail
return 1; //pass
    return 0;
and so on........
I recommend starting again with the email sketch (renamed of course), and slowly add stuff to make it work. Add a motionDetect() function like the example below. The motionDetect routine will return 1, indication there was motion detected. Now when you press 'e' and enter, you should get a "Motion detected" message on the serial monitor before it sends the email.
  byte inChar;
  if(inChar == 'e')
      if(motionDetect())
byte motionDetect()
   // your motion detect code here eventually
   return 1; // motion detected
   // return 0; // motion not detected
byte sendEmail()
   // the send email code here.
Start with that code and slowly modify it in stages, testing it as you go.
Thanx, I`ll try it!
Just so you can see how it works, try this:
comment out the "return 1;" and uncomment the "return 0;" in the motionDetect routine.
Then it will not display the "Motion detected", nor will it send the email, when you press the 'e'.
byte motionDetect()
   // return 1; // motion detected
Add: Eventually you will be able to remove the serial input 'e' trigger completely when the code is working as you expect. That will leave only the motionDetect() return value as the email trigger.
I've been copy/pasting everybody's code into the below that sends an email when pin 4 is touched to ground. Might be useful for testing.
12/21/11
SEND AN EMAIL WITH ARDUINO
 for IDE 1.0
 This code was created by modifying the connect example from
 arduino.cc and with the help of the YABB forums and their very
 helpful members. This code sends an email to any email address
 and then disconnects.
 Send e in serial monitor to send email
 touch pin 4 to ground to send email
#include <SPI.h>
// Change these next 4 entries to your network settings
byte ip[] = { 192, 168, 1, 102 };
byte gateway[] = { 192, 168, 1, 1 };
byte server[] = { abc, abc, abc, abc }; //smtp server ip address
EthernetClient client;
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
  delay(10);
  //Ethernet.begin(mac, ip); //subnet and gateway may not be needed
  Ethernet.begin(mac, ip, subnet, gateway);
  pinMode(button1, INPUT);
  digitalWrite(4, HIGH); //enable pullups to make pin high
  byte inChar;
  press1 = digitalRead(button1);
  if(inChar == 'e')
    if(sendEmail()) Serial.println("Serial Email sent"); //start sendEmail()
    else Serial.println("Serial Email failed");
   if (press1 == LOW)
    delay(2000);
    if(sendEmail()) Serial.println("Button Email sent"); //start sendEmail()
    else Serial.println("Button Email failed");
//////////////////////////////// email function
byte sendEmail()  //sendEmail() function that returns 1 or 0
  //start and check for email server connection
  if (client.connect(server,25)) {
  else {
    return 0; //send 0 (failed) back to sendEmail() function
  //wait for server "queing" response
  client.println("HELO itismeletschat"); /*hello (statement after helo is needed but irrelevant)*/
  //wait for server "hello" response
  client.println("MAIL From: me@myisp.net"); // identify sender, this should be the same as the smtp server you are using*/
  //wait for server "sender ok" response
  client.println("RCPT To: you@yourisp.net"); /* identify recipient */
  //wait for server "receipent ok" response
  client.println("DATA");
  //wait for server to say "enter your message" response
  //send email message to server
  client.println("To: you@yourisp.net"); /* identify recipient */
  client.println("Subject: You Have Arduino Mail!!"); /* insert subject */
  client.println("Please let me know it worked!!!"); /* insert body */
  client.println("."); /* end email */
  //wait for server "message accepted" response
  client.println("QUIT"); /* terminate connection */
  //wait for server "goodby" response
  //stop client connection
  client.stop();
  return 1; //send 1 (success) back to sendEmail() function
I think I`m almost there.
I combine al code and this looks like this:
#include <SPI.h>
byte ip[] = { 192, 168, 1, xxx};
byte gateway[] = { 192, xxx1, 254 };
byte subnet[] = { 255, xxx. 255, 0 };
byte server[] = { 194, xxx, 41, 21 };
  delay(10);
   if (motionDetect return 1);
    delay(2000);
byte motionDetect()
  int _input_pin;
  public:
  PassiveInfraredSensor(const int input_pin) {
  const bool motion_detected() const {
byte sendEmail()
  al the emailcode.....................
The only error I think there is is the trigger motiondetect return 1. Am I right and what is it I`m doing wrong?
You are very close! Just a small error here. The call to motionDetect() was incorrect. This is the correct way to call that function.
   if (motionDetect());
    delay(2000);
  // rest of code
There also needs to be two returns in the motionDetect() function. One for pass, the other for fail. Something like this:
byte motionDetect()
   byte mytest = 1;
   if(mytest == 1)
      // this will send the email
      return 1;
   // this will not
   return 0;
yes, but it keeps sending emails now. The trigger with the 'return 1' form the byte motiondetect isn`t correct I think but what is the problem...............?
Look at zoomkat's example a few posts above. He is using a pin state to send the email. My code will always send it, unless mytest is a pin state or other "volatile" variable.
That`s why I try this:
   digitalRead (HIGH);
    delay(2000);
but it keeps sending......I think I say with this: when in the function motiondetect the readpin is high (motion is detected) send a email.
You need to do that in the motionDetect routine. For a test, select a digital pin. I will use pin 5 as an example.
in the setup(), add
pinMode(5,INPUT);
digitalWrite(5,HIGH);
This will set pin 5 to input with a pullup resistor on that pin. To send email, connect pin 5 to ground.
byte motionDetect()
   if(digitalRead(5) == LOW)
      // returns 1 if pin is grounded
      return 1;
   // returns 0 if it isn't
   return 0;
You should become a bit more proficient at the C programming language if you wish to continue. These are basic C statements.
That semi-colon on the end is causing your grief. It IS the body to be executed when the statement is true. Remove is, and the stuff in the curly braces that follows the statement will become the body to be executed (which appears to be what you want).
Be aware that all pins don't seem to be equal when using my code. I tried adding additional button pins (I think I tried pin 5) and got the looping email sending (resulting in an emergency unplug of the USB cable to prevent blowing out my email in box!). I'll have to do more pin testing to see what the deal is.
I just looked at the schematics for the "old version" and the "new version" ethernet shields, and there is a pin difference, and not just 11-13.
The old shield uses digital pins pins 2-6 for something.
http://www.cutedigi.com/pub/Arduino/arduino-ethernet-shield-schematic.pdf
The new shield uses pins 0-4 for something. Pin 4 is the SD SPI Slave Select pin. No idea what the PD pins are (pins 0-3).
I`ve made some changes in my code and leave the idea of 'return'. I think this is for newbies like me easier.
This is the code:
#include <SPI.h>
byte ip[] = { 192, xxx, 1, 200 };
byte gateway[] = { 192, xxx, 1, xxx};
byte subnet[] = { 255, xxx, 255, 0 };
const int inputPin = 2;
  delay(10);
  delay(5000);
  pinMode (inputPin, INPUT);
void loop (){
  int val = digitalRead(inputPin);
  if (val == HIGH)
    delay(2000);
 byte sendEmail()
  byte thisByte = 0;
  byte respCode;
    return 0;
  if(respCode >= '4')
    efail();
    return 0;
  client.write("helo 83.xxx.xxx.134\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
  client.write("MAIL From: <xxx@online.nl>\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
// This must be a gmail.com domain to work if you are using Gmail
  client.write("RCPT To: <xxx@hotmail.com>\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
  client.write("To: xxx<xxx@hotmail.com>\r\n");
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
  thisByte = 0;
  if(respCode >= '4')
    efail();
    return 0;
  client.stop();
  return 1;
void efail()
  byte thisByte = 0;
  client.stop();
Are there disaventages doing it this way?
