Emailing instance variable how?(Solved, thanks Tim)
Hello everyone,
I have got a temperature logger for my fridge , once the temperature detected at 9 degree, it will email
me . and the temperature declared as : float temp ;
my question is , how can I or can I send the “temp” as temperature through email .
  • or I have to convert to string ?
I have tried this and got “time out”.
client.print((float)(temp -1));
I am new at this , please be kind :slight_smile:
This is Tim emailing code working great …
void whenTemperatureDetectsendEmail ()
    if (temp >= 9)
    if(sendEmail()) Serial.println("Email sent"); //start sendEmail()
}  else {
    Serial.println("Email failed");
//////////////////////////////// email function
byte sendEmail()  //sendEmail() function that returns 1 or 0
      byte thisByte = 0;
      byte respCode;
      if(client.connect(mailServer,25) == 1) {
        Serial.println(F("connected"));
        Serial.println(F("connection failed"));
        return 0;
      if(!eRcv()) return 0;
      Serial.println(F("Sending helo"));
    // change to your public ip
      client.println(F("EHLO      "));
      Serial.println(F("Sending From"));
    // change to your email address (sender)
      client.println(F("MAIL From: <myemail>"));
    // change to recipient address
      Serial.println(F("Sending To"));
      client.println(F("RCPT To: <myotheremail>"));
      Serial.println(F("Sending DATA"));
      client.println(F("DATA"));
      Serial.println(F("Sending email"));
      client.println(F("To: <myotheremail>"));
    // change to your address
      client.println(F("From:  <myemail>"));
      client.println(F("Subject:  Fridge needed Attention\r\n"));
      client.println(F("Temperature way above:"));
I NEED HELP HERE  ......................
   // client.print((float)(temp -1));
    client.println(F("."));
      Serial.println(F("Sending QUIT"));
      client.println(F("QUIT"));
      client.stop();
      Serial.println(F("disconnected"));
      return 1;
    byte eRcv()
      byte respCode;
      byte thisByte;
      int loopCount = 0;
      while(!client.available()) {
        delay(1);
        loopCount++;
        // if nothing received for 10 seconds, timeout
        if(loopCount > 10000) {
          client.stop();
          Serial.println(F("\r\nTimeout"));
          return 0;
      respCode = client.peek();
      while(client.available())
        thisByte = client.read();
        Serial.write(thisByte);
      if(respCode >= '4')
        efail();
        return 0;
      return 1;
    void efail()
      byte thisByte = 0;
      int loopCount = 0;
        delay(1);
        loopCount++;
          client.stop();
          return;
      client.stop();
I don't think client.print can convert a float. I haven't tried it lately. Last time I had to use dtostrf into a character array, then client.print it.. http://www.atmel.com/webdoc/AVRLibcReferenceManual/group__avr__stdlib_1ga060c998e77fb5fc0d3168b3ce8771d42.html
Thank you for quick reply Tim.. will working on it when I off work :)
I just tested the email send with the client.println((float)12.345,3); and it worked for me.
I sent an attached image with the float value and this is what I got in my email box:
This is an image from my Arduino! 12.345
Thank you Tim,
I just have to call the temperature again within the function , and it work great.
sensors.requestTemperatures(); // get data from DS18B20
//Serial.println(“Requesting temperatures”);
temp = sensors.getTempCByIndex(0);
and added
client.println((float)temp,2);
work great…
Thank you …
oh , one more question . can you give me some hints… what about if email doesn’t send…
I need to wait for 10 minutes and try again ?
    //Serial.println("Requesting temperatures");
    if (temp >= 9)
}  else {
      byte thisByte = 0;
      byte respCode;
        return 0;
      client.stop();
      return 1;
    byte eRcv()
      byte respCode;
      byte thisByte;
      int loopCount = 0;
        delay(1);
        loopCount++;
          client.stop();
          return 0;
      if(respCode >= '4')
        efail();
        return 0;
      return 1;
    void efail()
      byte thisByte = 0;
      int loopCount = 0;
        delay(1);
        loopCount++;
          client.stop();
          return;
      client.stop();
Correction Tim,
my "temp" variable already a global .
I used "client.print " instead of "client.println" .
client.println work great now ..
