Having trouble getting this nano to work with Arduino IDE.
This board is not a real Arduino Board! That being said, it is sold as being compatible to Atmel 328p.
Link Here: https://www.aliexpress.com/item/1005003884014135.html
The trouble I'm having is that I can not upload a basic sketch to this board using Arduion IDE. Any help would be greatly appreciated.
- Downloaded the files from GitHub. GitHub - nulllaborg/lgt8fx: Board Package for Logic Green LGT8F328P LGT8F328D and LGT8F88D
- Downloaded the driver for CH340 from GitHub. GitHub - adrianmihalko/ch340g-ch34g-ch34x-mac-os-x-driver: CH340G CH34G CH34X Mac OS X driver
- Installed the driver and put lgt8fx files in the Hardware folder as described.
- Followed the instructions on this GitHub page. GitHub - dbuezas/lgt8fx: Board Package for Logic Green LGT8F328P LGT8F328D and LGT8F88D
Read a lot, tried a few different things, Read some more, tried some other things, but just no luck getting the board to upload a sketch.
Tried to upload Bootloader to board, but couldn't get that to work either.
This is the error I'm getting:
Arduino: 1.8.19 (Mac OS X), Board: "LGT8F328, Default (64), Internal, 32 MHz, 328P-LQFP32 (e.g. MiniEVB nano-style and WAVGAT)"
Sketch uses 1052 bytes (3%) of program storage space. Maximum is 29696 bytes.
Global variables use 9 bytes of dynamic memory.
/Users/gordonbourey/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/gordonbourey/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-1420 -b57600 -D -Uflash:w:/var/folders/hy/znk2x5k524b791k990zrcym00000gn/T/arduino_build_889163/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/gordonbourey/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/gordonbourey/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-1420
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Thanks,
-g-
