Maybe this is a stupid question, but is it possible to have this code in the arduino? (html is new to me)
//Trying to show an embedded youtube video
client.println("<iframe width="560" height="315" src="http://www.youtube.com/embed/FqPtadgRIKI" frameborder="0" allowfullscreen></iframe>");
here is the complete code:
// ARDUINO WEB DISPLAY, BY PER EMIL SKJOLD
// for W5100 ethernet shield
// the IP address will be dependent on your local network/router
// port 80 is default for HTTP, but can be changed as needed
// use IP address like http://192.168.1.102/ in your brouser
#include <string.h>
#include <SPI.h>
#include <Ethernet.h>
int x=0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 10, 12 };
Server server(80);
float voltage=0;
float ut=0;
// start the server
Ethernet.begin(mac, ip);
server.begin();
// listen for incoming clients
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
// see if HTTP request has ended with blank line
if (c == '\n') {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
//meta-refresh page every 2 seconds
x=x+1;
client.print("<HEAD>");
client.print("<meta http-equiv=\"refresh\" content=\"5\">"); //5sek intervall
client.print("<TITLE />PES Network IO module 1</title>");
client.print("</head>");
client.println("PES IO module 1");
client.println("
"); //DENNE MÅ BRUKES FOR Å VISE LINJESKIFT
client.print("Antall sider sendt: ");
client.println(x);
client.println("
// client.println("
client.println("--------------------------");
client.println("
//ANALOGS
//TRYKK
//KONVERTER BYTE TIL NY DEFINISJON
//map(value, fromLow, fromHigh, toLow, toHigh)
//bar = map(analogRead(0), 0, 1023, 0, 100);
client.print("AI0 (Trykk) er ");
ut = analogRead(0) / 102.3;
client.print(ut,1); //EN DESIMAL
client.print(" bar");
client.println("
//TEMP LM335
client.print("AI1 (Temperatur) er ");
// float Kelvin = (((analogRead(1) / 1023) * 5) * 100);
// float Celsius = Kelvin-273;
// float Kelvin = analogRead(1) * 0.004882812 * 100;
// float Celsius = Kelvin - 273.15;
// InsideTemp.ReadTemp();
float tempK = analogRead(1) * 0.004882812 * 100; //Read temperature in Kelvins first
float tempC = tempK - 273.15 - 5;
client.print(tempC,0); //ingen DESIMAL
client.print(" grader celsius");
client.println("
// Serial.println(Celsius);
// delay(200);
// output the value of each analog input pin
for (int analogChannel = 2; analogChannel < 6; analogChannel++) {
client.print("AI");
client.print(analogChannel);
client.print(" er ");
client.print(analogRead(analogChannel));
// ut = analogRead(analogChannel) / 102.3; //gjør om enhet 1024 til 10.0bar
// client.print(ut,1); //EN DESIMAL
//client.print(" bar");
client.println("
//for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
// client.print("analog input ");
// client.print(analogChannel);
// client.print(" is ");
// client.print(analogRead(analogChannel));
// client.println("
client.println("
// output the value of each digital input pin
for (int digital = 2; digital < 13; digital++) {
client.print("DI");
client.print(digital);
client.print(digitalRead(digital));
client.println("
client.println("
client.println("By Per Emil Skjold");
client.println("
//Trying to show a dial from pachube.com
// client.println("<OBJECT classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0" WIDTH="200" HEIGHT="100" id="gauge"><PARAM NAME="movie" VALUE="http://apps.pachube.com/scaredycat/gauge.swf?xml_source=http%3A//apps.pachube.com/scaredycat/getData.php%3Fm%3D0%26f%3D13667%26s%3D0%26u%3D10%26l%3D0%26n%3D5%26t%3D123%26w%3Dfalse%26c1%3D33FF33%26c2%3DEFE415%26c3%3DEF8B15%26c4%3DFF3333%26in%3Dfalse" /><PARAM NAME="quality" VALUE="high" /><param name="wmode" value="transparent"><param name="allowScriptAccess" value="sameDomain" /><EMBED src="http://apps.pachube.com/scaredycat/gauge.swf?xml_source=http%3A//apps.pachube.com/scaredycat/getData.php%3Fm%3D0%26f%3D13667%26s%3D0%26u%3D10%26l%3D0%26n%3D5%26t%3D123%26w%3Dfalse%26c1%3D33FF33%26c2%3DEFE415%26c3%3DEF8B15%26c4%3DFF3333%26in%3Dfalse" quality="high" wmode="transparent" WIDTH="200" HEIGHT="100" NAME="gauge" allowScriptAccess="sameDomain" swLiveConnect="true" TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer"></EMBED></OBJECT>");
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
I get this error no matter what I try : error: expected `)’ before numeric constant
If this where possible, it would be nice. Then I could maybe embed a dial or something from pachube.com apps…
All help is much appreciated.
Per Emil S.
