EMIC 2 won't work
i hook up emic 2 and use the code provided by the manufacturer
  Emic 2 Text-to-Speech Module: Basic Demonstration
  Author: Joe Grand [www.grandideastudio.com]
  Contact: support@parallax.com
  Program Description:
  This program provides a simple demonstration of the Emic 2 Text-to-Speech
  Module. Please refer to the product manual for full details of system
  functionality and capabilities.
  Revisions:
  1.0 (February 13, 2012): Initial release
// include the SoftwareSerial library so we can use it to talk to the Emic 2 module
#include <SoftwareSerial.h>
#define rxPin 2    // Serial input (connects to Emic 2 SOUT)
#define txPin 3    // Serial output (connects to Emic 2 SIN)
#define ledPin 13  // Most Arduino boards have an on-board LED on this pin
// set up a new serial port
SoftwareSerial emicSerial =  SoftwareSerial(rxPin, txPin);
void setup()  // Set up code called once on start-up
  // define pin modes
  pinMode(ledPin, OUTPUT);
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  // set the data rate for the SoftwareSerial port
  emicSerial.begin(9600);
  digitalWrite(ledPin, LOW);  // turn LED off
    When the Emic 2 powers on, it takes about 3 seconds for it to successfully
    intialize. It then sends a ":" character to indicate it's ready to accept
    commands. If the Emic 2 is already initialized, a CR will also cause it
    to send a ":"
  emicSerial.print('\n');             // Send a CR in case the system is already up
  while (emicSerial.read() != ':');   // When the Emic 2 has initialized and is ready, it will send a single ':' character, so wait here until we receive it
  delay(10);                          // Short delay
  emicSerial.flush();                 // Flush the receive buffer
void loop()  // Main code, to run repeatedly
  // Speak some text
  emicSerial.print('S');
  emicSerial.print("Hello. My name is the Emic 2 Text-to-Speech module. I would like to sing you a song.");  // Send the desired string to convert to speech
  digitalWrite(ledPin, HIGH);         // Turn on LED while Emic is outputting audio
  while (emicSerial.read() != ':');   // Wait here until the Emic 2 responds with a ":" indicating it's ready to accept the next command
  delay(500);    // 1/2 second delay
  // Sing a song
  emicSerial.print("D1\n");
  while(1)      // Demonstration complete!
sout -> D2
sin -> D3
gnd->gnd
5v->5v
i did try 5 different 8 ohm speakers and not a sound
the on board led does turn led whenever the arduino send data to it to talk (from green ideal -> red indicate active) also the arduino led turns on when the on board led is red (active), which means that data are transmitted and the board process it and should be talking
so what could have gone wrong ?
There are no problems in the code, as long as you have downloaded the libraries it should work. The led on board the module means it is ouputing a signal to the speaker. My advice is to use earbuds or a speaker with an aux jack and plug it into the module.If it still doesn't work it may be defective.
