Hello,
I have designed a little board to read 4 SCT-013 60A/1V Sensors. All wired up like this. Board is an Arduino Nano.
I now have the strange behavoir, that the values of two inputs work fine, but the other two not. I have read the analog inputs directly to see if there is something wrong but for me all looks ok.
Do you have any Idea why input 3 und 4 (gree and yellow) work and 1 and 2 (blue and red) not?
1 and 2 have a little lower voltage, but I don't think that should be a problem.
Thank You
Here are the plots.
Analog inputy read directly without load
Code.
When I set DEBUG to false I get the output of Emonlib, if I set it to true I get the direct readings
#include "EmonLib.h"
EnergyMonitor emon1,emon2,emon3,emon4;
#define DEBUG false
#define ADC_INPUT1 1
#define ADC_INPUT2 2
#define ADC_INPUT3 3
#define ADC_INPUT4 4
Serial.begin(500000);
if (!DEBUG)
emon1.current(ADC_INPUT1, 111.1);
emon2.current(ADC_INPUT2, 111.1);
emon3.current(ADC_INPUT3, 111.1);
emon4.current(ADC_INPUT4, 111.1);
if (not DEBUG)
double Irms1 = emon1.calcIrms(1480);
double Irms2 = emon2.calcIrms(1480);
double Irms3 = emon3.calcIrms(1480);
double Irms4 = emon4.calcIrms(1480);
Serial.print(Irms1);
Serial.print(" ");
Serial.print(Irms2);
Serial.print(" ");
Serial.print(Irms3);
Serial.print(" ");
Serial.print(Irms4);
Serial.print(analogRead(ADC_INPUT1));
Serial.print(" ");
Serial.print(analogRead(ADC_INPUT2));
Serial.print(" ");
Serial.print(analogRead(ADC_INPUT3));
Serial.print(" ");
Serial.print(analogRead(ADC_INPUT4));
