Emulating a memristor using arduino uno, but my code is for an arduino due..
I wanted to ask if their was a big difference in between the coding for an arduino uno and arduino due
#include <SPI.h>
// Define I/O pins
#define SLAVESELECT 4 // set pin 4 as the slave select for the digital potentiometer
// opcodes
#define WRITE_W0 0
#define WRITE_W1 16
#define init_W0 230 // The MCP4151 default wiper position is in the mid- sacale so we initialise both wiper position to a resistance equivalent to Rinit right in the setup code
#define init_W1 0
#define init_state 128 // initial resistance can go from 1 - 255
// Memristor parameter definition and default values
const double Ron = 2000.0;
const double Roff = 50000.0;
const double D = 0.000000001;
float VT = 0.2;
const double uv = 0.0000000000001;
double dwdt;
double dw;
double w;
double Imem;
double Imessage;
double Vmem;
double wlast;
double winit;
double Number;
double dt = 0.000015;
double Rinit = 45000.0;
double Rmem;
int N;
int Rw = 75;
long Iteration = 0;
double J = 1.0;
double p_coeff = 2.0;
double sign_multiply;
double noise = 0.00000000000000001;
int POBVoltageValue;
int WiperVoltageValue;
double POBvoltage;
double Wipervoltage;
//put your setup code here, to run once;
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode (A4, OUTPUT);
pinMode(A5, OUTPUT);
//SPI.begin (SLAVESELECT); // initialize SPI:
Serial.begin(9600); // initialize serial communication at 9600 bits per second:
Serial.write('\n'); // debug
// set initial wiper condition (Rinit)
digitalPotWrite (WRITE_W0, init_W0);
// change the arduino Due ADC/DAC resoultion to 12 bits
int analogReadResolution(12);
int analogWriteResolution(12);
analogWrite(A4, 2047);
dw=(uv * Ron)/D;
winit=D/10;
wlast=winit;
Rmem=Rinit;
void loop (){
if (Iteration == 0){
  digitalPotWrite(WRITE_W0, init_W0);
Iteration++;
//read the inputu on analog pin 0 and 1;
POBVoltageValue=analogRead(A0);
WiperVoltageValue= analogRead(A1);
//Convert the analog reading ( which goes from 0 - 4095) to a voltage (0 - 3.3V);
POBvoltage=POBVoltageValue*(3.3/4095.0);
Wipervoltage=WiperVoltageValue*(3.3/4095.0);
Vmem=Wipervoltage-POBvoltage;
Imem = Vmem/Rmem;
Imessage= 1000000.0*Imem;
dwdt=dw*Imem;
if(func(Imem)==1){
  sign_multiply=0.0;
if(w==0){
  sign_multiply=1.0;}
if(func(Imem)==-1){
  sign_multiply=0.0;
if(w==D){sign_multiply=-1.0;
if((abs(Vmem))<VT){
  w=wlast;
else{
  w=dwdt*dt*J*(1-(pow(pow((w/D)-0.5,2)+0.75,
p_coeff)))+wlast+(sign_multiply*noise);
if(w>=D){
  w=D;
if(w<=0){
  w=0;
Rmem=(Ron*(w/D)+Roff*((1-w)/D));
wlast=w;
Number=(((Rmem-Rw)*256)/Roff);
N=round(Number);
digitalPotWrite(WRITE_W0,N);
TimePlot(Imessage,"Current","I");
Serial.println("{TIMEPLOT:I | set | title=Curent}");
Serial.println("{TIMEPLOT:I | set | x-label=Time}");
Serial.println("{TIMEPLOT:I | set | y-label=I(uA)}");
TimePlot(Vmem, "Input_Voltage","V");
Serial.println("{TIMEPLOT:I | set | title=Voltage}");
Serial.println("{TIMEPLOT:I | set | y-label=V(V)}");
XYPlot(Vmem,Imessage, "i-v","i-curve");
Serial.println("{XYPLOT:curve | set | title=i-v}");
Serial.println("{XYPLOT:curve | set | x-label=V(V)}");
Serial.println("{XYPLOT:curve | set | Y-label=I(uA)}");
int func(double arg){
int sign;
sign=(arg >=0.0?1:-1);
return sign ;
void digitalPotWrite(int command, int value){
SPI.transfer(SLAVESELECT, command);
SPI.transfer(SLAVESELECT, value);
void TimePlot(float data, String seriesName, String channelName){
Serial.print ("{TIMEPLOT:");
Serial.print (channelName);
Serial.print("|data|");
Serial.print(seriesName);
Serial.print("|T|");
Serial.print(data, 3);
Serial.println("}");
void XYPlot( float xData, float yData,String seriesName,String channelName){
Serial.print("{XYPLOT:");
Serial.print(channelName);
Serial.print("| data |");
Serial.print("|");
Serial.print(xData);
Serial.print("|");
Serial.print(yData);
These are my four errors also received when running the code
/Users/nas.the.rapper/Downloads/Code/Code.ino: In function 'void digitalPotWrite(int, int)':
/Users/nas.the.rapper/Downloads/Code/Code.ino:123:34: warning: invalid conversion from 'int' to 'void*' [-fpermissive]
In file included from /Users/nas.the.rapper/Downloads/Code/Code.ino:1:0:
/Users/nas.the.rapper/Desktop/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.h:244:22: note:   initializing argument 1 of 'static void SPIClass::transfer(void*, size_t)'
   inline static void transfer(void *buf, size_t count) {
/Users/nas.the.rapper/Downloads/Code/Code.ino:124:32: warning: invalid conversion from 'int' to 'void*' [-fpermissive]
Sketch uses 7160 bytes (22%) of program storage space. Maximum is 32256 bytes.
Global variables use 600 bytes (29%) of dynamic memory, leaving 1448 bytes for local variables. Maximum is 2048 bytes.
No, and yes. The DUE has hardware that the UNO does not, like a true variable voltage output. That code is expecting that hardware to exist.
You can't run code that won't compile.
int sign;
return sign ;
What a waste, using 4 bytes to get one bit of information.
RTFM: SPI.transfer
Thanks for the help
