Emulating CID of SD-Card as MITM
Hello,
i am looking for a way to spoof the CID part of an SD Card with different, sepcific data. Therefore i thought to place an Arduino "in-band" to the SD card an the device slot. Traffic should pass through, expect of the SEND_CID command (CMD10).
For know i know that an Arduino can't handle the high datarates of SD traffic itself, but the initialization phase, and hopefully the above cmd also, are done much slower (400 khz?!).
So, i can build a repeater, but had to build some kind of digital switch and listen to the MOSI line until i see the request. As soon as i detect it, i need to "cut" the MISO line, so it is connected to my Arduino instead of the SD card. Then i send my own CID to the host. To know when to switch back to bypassmode, i think i had to gather SD card output also until it fully send its answer. Think i had to delay my output until SD is done.
Do you folks think this is possible at all?
How do you know that the Arduino isn't fast enough?
Given that most SD cards are going to be moving megabytes per second I suspect that a 16MHz Arduino isn't actually fast enough so I would start experimenting with a Teensy, since I have many of them available to me.
Remember that a fast SD interface is not using the SPI protocol. It's using all the pins on the card and it won't be obeying simple rules like MOSI and CS.
