I'm using the SX127XLT library to using the LORA SX1278 module and image transferring . As far as I know, in the LORA module, using DIO0, a wake-up source can be used when receiving a message. I have used ESP pin 14 to wake up ESP32CAM and receiving data. But when the transmitter sends a message, there is no change in pin 14 level to wake up the board. please guide me.
The code I use to wake up the board is as follows. The module settings are as follows:
settings.h file:
Programs for Arduino - Copyright of the author Stuart Robinson - 20/03/22
This program is supplied as is, it is up to the user of the program to decide if the program is
suitable for the intended purpose and free from errors.
#define NSS 12 //select on LoRa device
#define NRESET 15 //reset pin on LoRa device
#define SCK 4 //SCK on SPI3
#define MISO 13 //MISO on SPI3
#define MOSI 2 //MOSI on SPI3
#define REDLED 33 //pin number for ESP32CAM on board red LED, set logic level low for on
#define IRQPIN 14 //ASD
#define LORA_DEVICE DEVICE_SX1278 //this is the device we are using
//******* Setup LoRa modem parameters here ! ***************
const uint32_t Frequency = 434000000; //frequency of transmissions in hertz
const uint32_t Offset = 0; //offset frequency for calibration purposes
const uint8_t Bandwidth = LORA_BW_500; //LoRa bandwidth
const uint8_t SpreadingFactor = LORA_SF7; //LoRa spreading factor
const uint8_t CodeRate = LORA_CR_4_5; //LoRa coding rate
const uint8_t Optimisation = LDRO_AUTO; //low data rate optimisation setting, normally set to auto
const int8_t TXpower = 15; //LoRa transmit power in dBm
const uint32_t TXtimeoutmS = 5000; //mS to wait for TX to complete
const uint32_t RXtimeoutmS = 3000000; //mS to wait for receiving a packet
const uint32_t ACKdelaymS = 0; //ms delay after general packet actioned and ack sent
const uint32_t ACKdelaystartendmS = 25; //ms delay before ack sent at array start wrie and end write
const uint32_t ACKsegtimeoutmS = 75; //mS to wait for receiving an ACK before re-trying transmit segment
const uint32_t ACKopentimeoutmS = 250; //mS to wait for receiving an ACK before re-trying transmit file open
const uint32_t ACKclosetimeoutmS = 250; //mS to wait for receiving an ACK before re-trying transmit file close
const uint32_t DuplicatedelaymS = 25; //ms delay if there has been an duplicate segment or command receipt
const uint32_t NoAckCountLimit = 250; //if no NoAckCount exceeds this value - restart transfer
const uint32_t FunctionDelaymS = 0; //delay between functions such as open file, send segments etc
const uint32_t PacketDelaymS = 1000; //mS delay between transmitted packets such as DTInfo etc
const uint32_t ReceiveTimeoutmS = 60000; //mS waiting for array transfer before timeout
const uint8_t HeaderSizeMax = 12; //max size of header in bytes, minimum size is 6 bytes
const uint8_t DataSizeMax = 245; //max size of data array in bytes
const uint8_t ARDTfilenamesize = 32; //size of DTfilename buffer used by array transfer functions
const uint32_t ARDTarraysize = 0x20000; //maximum file\array size to receive
const uint16_t NetworkID = 0x3210; //a unique identifier to go out with packet
const uint8_t StartAttempts = 2; //number of attempts to start transfer before a fail
const uint8_t SendAttempts = 5; //number of attempts carrying out a process before a restart
const uint8_t SegmentSize = 245; //number of bytes in each segment, 245 is maximum value for LoRa
Reciever Code :
#include <SPI.h>
#include "FS.h" //SD Card ESP32
#include "SD_MMC.h" //SD Card ESP32
#include "soc/soc.h" //disable brownout problems
#include "soc/rtc_cntl_reg.h" //disable brownout problems
#include "driver/rtc_io.h"
#include <SX127XLT.h> //SX12XX-LoRa library
#include <ProgramLT_Definitions.h> //part of SX12XX-LoRa library
#include "Settings.h" //LoRa settings etc.
#define ENABLEMONITOR //enable this define to monitor data transfer information, needed for ARtransferIRQ.h
#define ENABLEARRAYCRC //enable this define to check and print CRC of sent array
#define PRINTSEGMENTNUM //enable this define to print segment numbers during data transfer
//#define DISABLEPAYLOADCRC //enable this define if you want to disable payload CRC checking
//#define DEBUG //enable more detail of transfer progress
SX127XLT LoRa; //create an SX127XLT library instance called LoRa
#include <ARtransferIRQ.h>
uint8_t *PSRAMptr; //create a global pointer to the array to send, so all functions have access
bool SDOK;
bool savedtoSDOK;
uint32_t arraylength;
SDOK = false;
Serial.println(F("LoRa file transfer receiver ready"));
setupLoRaDevice();
delay(3000);
digitalWrite(NSS, LOW);
delay(100);
esp_sleep_enable_ext0_wakeup(GPIO_NUM_14,1); //1 = High, 0 = Low
Serial.println("Going to sleep now");
esp_deep_sleep_start();
bool setupLoRaDevice()
SPI.begin(SCK, MISO, MOSI, NSS);
if (LoRa.begin(NSS, NRESET,IRQPIN, LORA_DEVICE))
Serial.println(F("LoRa device found"));
Serial.println(F("LoRa Device error"));
return false;
LoRa.setupLoRa(Frequency, Offset, SpreadingFactor, Bandwidth, CodeRate, Optimisation);
#ifdef DISABLEPAYLOADCRC
LoRa.setReliableConfig(NoReliableCRC);
#endif
if (LoRa.getReliableConfig(NoReliableCRC))
Serial.println(F("Payload CRC disabled"));
Serial.println(F("Payload CRC enabled"));
return true;
void led_Flash(uint16_t flashes, uint16_t delaymS)
uint16_t index;
for (index = 1; index <= flashes; index++)
digitalWrite(REDLED, HIGH);
delay(delaymS);
digitalWrite(REDLED, LOW);
delay(delaymS);
uint32_t available_PSRAM_size;
uint32_t new_available_PSRAM_size;
//WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
pinMode(REDLED, OUTPUT); //setup pin as output for indicator LED
led_Flash(2, 125); //two quick LED flashes to indicate program start
ARsetDTLED(REDLED); //setup LED pin for data transfer indicator
digitalWrite(NSS, HIGH);
pinMode(NSS, OUTPUT); //disable LoRa device for now
Serial.println(__FILE__);
if (psramInit())
Serial.println("PSRAM is correctly initialised");
available_PSRAM_size = ESP.getFreePsram();
Serial.println((String)"PSRAM Size available: " + available_PSRAM_size);
Serial.println("PSRAM not available");
while (1);
Serial.println("Allocate array in PSRAM");
uint8_t *byte_array = (uint8_t *) ps_malloc(ARDTarraysize * sizeof(uint8_t));
PSRAMptr = byte_array; //save the pointe to byte_array to global pointer
new_available_PSRAM_size = ESP.getFreePsram();
Serial.println((String)"PSRAM Size available: " + new_available_PSRAM_size);
Serial.print("PSRAM array bytes allocated: ");
Serial.println(available_PSRAM_size - new_available_PSRAM_size);
Serial.println("Hi .......... ..");
setupLoRaDevice();
