Hello,
I’m running a Nano (ATmega328), and noticed that enabling pwm on a single pin in the setup() section slows down the loop() section considerably.
The code below takes ~12 seconds to complete the while loop if lines starting TCCR0B and analogWrite are commented out, ~20 seconds if they’re left in.
My understanding is that pwm on the ATmega328 is implemented in hardware, so I’m at a loss to understand why the loop() section is interrupted if pwm is enabled.
Is this normal behaviour for the ATmega328, and is there anything that can be done to reduce the increased execution time while pwm is active?
The code below will compile for a Nano. The program has no practical use other than to demonstrate the phenomenon I’m seeing. I would like to use pwm in another real-time program I’m writing, but the hit on speed is a problem with pwm enabled. Pwm is set to 62.5 KHz because the default arduino frequencies are too low for my application.
I’ve searched all the documentation I can find on the analogWrite call but I’ve not found anything on its impact to main program execution.
Regards,
#include <avr/pgmspace.h>
long i;
Serial.begin(4800);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
//TCCR0B = (TCCR0B & 0b11111000) | 0x01;; // pin 6 PWM frequency 62500 Hz (62500/1)
//analogWrite(6, 0);
//loop takes 12 seconds without pwm, 20 seconds with pwm
i=0;
while (i<5000000) {
PORTD = PORTD | B10000000; //pin 7 HIGH
PORTD = PORTD & B01111111; //pin 7 LOW
i++;
Serial.print("Done ");
