Enc28J60 doesn't work as a web client
My Enc28J60 chip cannot connect as a web client although it's works fine as a web server!
the chip connected to laptop which has a wireless connection with the router and i use Enc28j60 library and IDE 0023(the original Ethernet library was removed from the library folder).
the web client code:
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 105 }; // my ethernet ip is(192.168.1.104) so this is in the same subnet
byte server[] = { 173, 194, 70, 138 }; //google ip
Client client(server, 80);
Ethernet.begin(mac, ip);
Serial.println("connecting...");
if (client.connect()) { // i think the problem is here?!
Serial.println("connected");
client.println("GET /search?q=arduino HTTP/1.0");
client.println();
else {
Serial.println("connection failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
for(;; )
the serial monitor output:
connecting...
connection failed
disconnecting.
i spent 2 weeks searching for solutions :S could any one help me in this problem?
thanks in advance
There has been a lot of bug fixes and updates since that version.
Please use the newest version. At the moment Arduino version 1.0.5.
You can unzip the new version in a seperate folder, so you can use both version.
The Arduino ethernet libary is for the Ethernet Shield with W5100 chip.
The ENC28J60 is not officially supported.
If you would use the Ethernet Shield, you can use all the examples for that. That would be a lot easier.
If you still want to use the ENC28J60, I suggest to start first with the newest Arduino 1.0.5 version.
Next step is to find a good library for it. In my opinion, the Ethercard library the only good library.
The way it is used it not the same as with the Arduino Ethernet library. But with the examples, you should be able to make it work.
Thanks , i will try and i hope to get it work
