ENC28J60 / EtherCard library && OSCuino library?
Has anyone had any success getting these two to play with each other?
The examples are set up to work with Arduino's vanilla Ethernet library and Ethernet shield. I was hoping I could just cast the OSCMessage object as a String (i.e. char Array), and send it out of EtherCard's ether.udpSend() function call, but it's not letting me cast because OSCMessage appears to not really be a syntactically castable object.
Thoughts?
Thanks!
Use the getbytes() or toString()
OSCMessage is an object, though, not a string. As far as I can tell, I might need to jump into the header and cpp and rip some stuff out and make it public in order to re-objectify the payload of the message... but I'm hoping I don't have to do that.
