ENC28J60 Ethernet Module and MEGA2560 I did with webduino webserver does not open.
project code
#include "SPI.h"
#include "Ethernet.h"
#include "WebServer.h"
// no-cost stream operator as described at
// http://sundial.org/arduino/?page_id=119
template<class T>
inline Print &operator <<(Print &obj, T arg)
{ obj.print(arg); return obj; }
// CHANGE THIS TO YOUR OWN UNIQUE VALUE
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// CHANGE THIS TO MATCH YOUR HOST NETWORK
static uint8_t ip[] = { 192, 168, 1, 210 };
#define PREFIX ""
WebServer webserver(PREFIX, 80);
// commands are functions that get called by the webserver framework
// they can read any posted data from client, and they output to server
void jsonCmd(WebServer &server, WebServer::ConnectionType type, char *url_tail, bool tail_complete)
if (type == WebServer::POST)
server.httpFail();
return;
//server.httpSuccess(false, "application/json");
server.httpSuccess("application/json");
if (type == WebServer::HEAD)
return;
int i;
server << "{ ";
for (i = 0; i <= 9; ++i)
// ignore the pins we use to talk to the Ethernet chip
int val = digitalRead(i);
server << "\"d" << i << "\": " << val << ", ";
for (i = 0; i <= 5; ++i)
int val = analogRead(i);
server << "\"a" << i << "\": " << val;
if (i != 5)
server << ", ";
server << " }";
void outputPins(WebServer &server, WebServer::ConnectionType type, bool addControls = false)
P(htmlHead) =
"<html>"
"<head>"
"<title>Arduino Web Server</title>"
"<style type=\"text/css\">"
"BODY { font-family: sans-serif }"
"H1 { font-size: 14pt; text-decoration: underline }"
"P { font-size: 10pt; }"
"</style>"
"</head>"
"<body>";
int i;
server.httpSuccess();
server.printP(htmlHead);
if (addControls)
server << "<form action='" PREFIX "/form' method='post'>";
server << "<h1>Digital Pins</h1><p>";
server << "Digital " << i << ": ";
if (addControls)
char pinName[4];
pinName[0] = 'd';
itoa(i, pinName + 1, 10);
server.radioButton(pinName, "1", "On", val);
server << " ";
server.radioButton(pinName, "0", "Off", !val);
server << (val ? "HIGH" : "LOW");
server << "
server << "</p><h1>Analog Pins</h1><p>";
server << "Analog " << i << ": " << val << "
server << "</p>";
if (addControls)
server << "<input type='submit' value='Submit'/></form>";
server << "</body></html>";
void formCmd(WebServer &server, WebServer::ConnectionType type, char *url_tail, bool tail_complete)
bool repeat;
char name[16], value[16];
do
repeat = server.readPOSTparam(name, 16, value, 16);
if (name[0] == 'd')
int pin = strtoul(name + 1, NULL, 10);
int val = strtoul(value, NULL, 10);
digitalWrite(pin, val);
} while (repeat);
server.httpSeeOther(PREFIX "/form");
outputPins(server, type, true);
void defaultCmd(WebServer &server, WebServer::ConnectionType type, char *url_tail, bool tail_complete)
outputPins(server, type, false);
// set pins 0-8 for digital input
for (int i = 0; i <= 9; ++i)
pinMode(i, INPUT);
pinMode(9, OUTPUT);
Ethernet.begin(mac, ip);
webserver.begin();
webserver.setDefaultCommand(&defaultCmd);
webserver.addCommand("json", &jsonCmd);
webserver.addCommand("form", &formCmd);
// process incoming connections one at a time forever
webserver.processConnection();
// if you wanted to do other work based on a connecton, it would go here
But you use the following code opens.
// A simple web server that always just says "Hello World"
#include "etherShield.h"
#include "ETHER_28J60.h"
int outputPin = 6;
static uint8_t mac[6] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24}; // this just needs to be unique for your network,
// so unless you have more than one of these boards
// connected, you should be fine with this value.
static uint8_t ip[4] = {192, 168, 1, 15}; // the IP address for your board. Check your home hub
// to find an IP address not in use and pick that
// this or 10.0.0.15 are likely formats for an address
// that will work.
static uint16_t port = 80; // Use port 80 - the standard for HTTP
ETHER_28J60 e;
e.setup(mac, ip, port);
pinMode(outputPin, OUTPUT);
char* params;
if (params = e.serviceRequest())
e.print("<H1>Web Remote</H1>");
if (strcmp(params, "?cmd=on") == 0)
digitalWrite(outputPin, HIGH);
e.print("<A HREF='?cmd=off'>Turn off</A>");
else if (strcmp(params, "?cmd=off") == 0) // Modified -- 2011 12 15 # Ben Schueler
digitalWrite(outputPin, LOW);
e.print("<A HREF='?cmd=on'>Turn on</A>");
e.respond();
to reduce costs ENC28J60 Ethernet Module need to use how can I solve this problem ?
