ENC28J60 ETHERNET SHIELD CAN ONLY CONTROL 4 OUTPUTS?
Sir/Mam, when we try to add more than 4 outputs to control in our arduino code, the android application we created (using basic4android) can't seem to control our output pins. But functions well when we only include 4.
Does it mean that an ethernet enc28j60 can only control 4 outputs? Or there is a simple possible solution to this problem..thanks :)
Friend, with a post like this you will never get any replies.
ENC28J60 is nothing but an Ethernet controller chip or add-on to an Arduino controller. So your post doesn't make sense. If you can establish communication between your controller and the application, you should not be limited to 4.
If you need help, you will need to follow the instructions when posting.
