ENC28j60 fails to setup DHCP
Hi
I am trying to connect my Arduino Uno microcontroller to my network by connecting the LAN cable from my Motorola router to the ENC28j60 ethernet module which is connected to the Arduino Uno as:
VCC – 3.3V
GND – GND
SCK – Pin 13
SO – Pin 12
SI – Pin 11
CS – Pin 8
My router's address is 192.168.0.1 . I am using the EtherCard library but I get the following error on my Serial Monitor:
Trying to get an IP...
MAC: 74:69:69:2D:30:31
Setting up DHCP
DHCP failed
I am using the following sketch:
#include <EtherCard.h>
#define STATIC 0  // set to 1 to disable DHCP (adjust myip/gwip values below)
// mac address
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
// ethernet interface ip address
static byte myip[] = { 192,168,0,200 };
// gateway ip address
static byte gwip[] = { 192,168,0,1 };
// LED to control output
int ledPin10 = 10;
byte Ethernet::buffer[700];
char page[] PROGMEM =
"HTTP/1.0 503 Service Unavailable\r\n"
"Content-Type: text/html\r\n"
"Retry-After: 600\r\n"
"\r\n"
"<html>"
  "<head><title>"
    "Service Temporarily Unavailable"
  "</title></head>"
  "<body>"
    "<h3>This service is currently unavailable</h3>"
    "<p><em>"
      "The main server is currently off-line.
      "Please try again later."
    "</em></p>"
  "</body>"
"</html>"
void setup () {
  pinMode(ledPin10, OUTPUT);
  Serial.println("Trying to get an IP...");
  Serial.print("MAC: ");
  for (byte i = 0; i < 6; ++i) {
    Serial.print(mymac[i], HEX);
    if (i < 5)
      Serial.print(':');
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println( "Failed to access Ethernet controller");
#if STATIC
  Serial.println( "Getting static IP.");
  if (!ether.staticSetup(myip, gwip)){
    Serial.println( "could not get a static IP");
    blinkLed();     // blink forever to indicate a problem
#else
  Serial.println("Setting up DHCP");
  if (!ether.dhcpSetup()){
    Serial.println( "DHCP failed");
#endif
  ether.printIp("My IP: ", ether.myip);
  ether.printIp("Netmask: ", ether.mymask);
  ether.printIp("GW IP: ", ether.gwip);
  ether.printIp("DNS IP: ", ether.dnsip);
void loop () {
  word len = ether.packetReceive();
  word pos = ether.packetLoop(len);
  // IF LED10=ON turn it ON
  if(strstr((char *)Ethernet::buffer + pos, "GET /?LED10=ON") != 0) {
      Serial.println("Received ON command");
      digitalWrite(ledPin10, HIGH);
    // IF LED10=OFF turn it OFF
    if(strstr((char *)Ethernet::buffer + pos, "GET /?LED10=OFF") != 0) {
      Serial.println("Received OFF command");
      digitalWrite(ledPin10, LOW);
    // show some data to the user
    memcpy_P(ether.tcpOffset(), page, sizeof page);
    ether.httpServerReply(sizeof page - 1);
void blinkLed(){
  while (true){
Please let me know what I am doing wrong. I even tried disabling DHCP to get a static IP but what I get is 0.0.0.0
