#include "etherShield.h"
// please modify the following two lines. mac and ip have to be unique
// in your local area network. You can not have the same numbers in
// two devices:
static uint8_t mymac[6] = {
0x54,0x55,0x58,0x10,0x00,0x24};
static uint8_t myip[4] = {
192,168,16,15};
// how did I get the mac addr? Translate the first 3 numbers into ascii is: TUX
#define BUFFER_SIZE 250
unsigned char buf[BUFFER_SIZE+1];
uint16_t plen;
EtherShield es=EtherShield();
void setup(){
/*initialize enc28j60*/
es.ES_enc28j60Init(mymac);
es.ES_enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
delay(10);
/* Magjack leds configuration, see enc28j60 datasheet, page 11 */
// LEDA=green LEDB=yellow
// 0x880 is PHLCON LEDB=on, LEDA=on
// enc28j60PhyWrite(PHLCON,0b0000 1000 1000 00 00);
es.ES_enc28j60PhyWrite(PHLCON,0x880);
// 0x990 is PHLCON LEDB=off, LEDA=off
// enc28j60PhyWrite(PHLCON,0b0000 1001 1001 00 00);
es.ES_enc28j60PhyWrite(PHLCON,0x990);
// 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit
// enc28j60PhyWrite(PHLCON,0b0000 0100 0111 01 10);
es.ES_enc28j60PhyWrite(PHLCON,0x476);
delay(100);
//init the ethernet/ip layer:
es.ES_init_ip_arp_udp_tcp(mymac,myip,80);
void loop(){
plen = es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf);
/*plen will be unequal to zero if there is a valid packet (without crc error) */
if(plen!=0){
if(es.ES_eth_type_is_arp_and_my_ip(buf,plen)){
es.ES_make_arp_answer_from_request(buf);
// check if ip packets (icmp or udp) are for us:
if(es.ES_eth_type_is_ip_and_my_ip(buf,plen)!=0){
if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){
// a ping packet, let's send pong
es.ES_make_echo_reply_from_request(buf,plen);
chromus:
Are you saying that if I adjust those values to match the pins for the mega (50-52) or (50-53) it should work?
Rather I'm saying if you don't change it, it WON'T work Certainly worth trying, though there may be something else too.
chromus:
A few things about Arduino irritate me including the forward/backward compatibility issues, but this isn't the place to grumble about things.
This incompatibility isn't Arduino's fault, it's all on the EtherShield library. Most people don't write their libraries to be Mega-compatible. But hey, it's free code.
The pins on the ENC are rated 3.3v but are 5v tolerant. However the voltage for powering the module is 3.3 volts.
Check you have a 3.3 volts on pin 9 and gnd of the power supply and Mega to pin 10 of module.
The Geetech manual shows the module running off VCC from the Arduino. THis would be fine if they had a regulator on the ENC module but the schematic for it shows no such voltage reduction. The Microchip ENC28J60 datasheet states that the ENC is a 3.3 volt device. Unless your Arduino is has A VCC of 3.3v you will damage the chip connecting pin 9 directly to VCC.
The Nuelectronics ENC28J60 shield schematic clearly shows the 3.3v onboard regulator and signal level shifters. Yours does not have these niceties but will still work if care is taken.
I can't recall if there is a 3.3v output on the Mega but do not use this if there is as it is usually only rated to 50 ma(from memory). Typically network modules pull ~100-250 ma.
Try connecting the module and PC to a ethernet hub/switch (instead of directly to each other) in case the crossover detection isn't working.
Also try cutting and pasting the code from the Geeetech "Manual source code.pdf" for a test sketch:
Thanks for your help lemming. The issue is now fixed
The 3.3v out on the mega seems happy supplying the constant 75ma that my multimeter says the module is drawing.
The resolution was in the end connecting the VCC to the 3.3v, I had mis-understood the description and had been working on the assumption that the power input was 5v tolerant as well as the data pins.
