ENC28j60 Not Working
Hello everyone, ihave uno and enc28j60 mini network module but not working.Iā€™m upload testDHCP skecth but arduino respond random texts.Please help me :slight_smile:
my conn diagram;
  • ENC SO ā†’ Arduino pin 12
  • ENC SI ā†’ Arduino pin 11
  • ENC SCK ā†’ Arduino pin 13
  • ENC CS ā†’ Arduino pin 8
  • ENC VCC ā†’ Arduino 3V3 pin
  • ENC GND ā†’ Arduino Gnd pin
The picture of the code says that the baud rate is 57600. The picture of the Serial Monitor application says that the baud rate is 9600. One of them is wrong.
oh, i set this 9600 but returns noting :( when eject ethernet cable says "DHCP FAILED"
In your your text the CS signal is connected to pin 8, it's normally pin 10 for Ethernet. But in your sketch I don't see any reference to pin 8 (or normally 10).
buraktncblk: oh, i set this 9600 but returns noting :( when eject ethernet cable says "DHCP FAILED"
Start with having your router assign the Arduino a static IP address. Have the Arduino use that static IP address.
Have you tried the backSoon sketch from the examples? Remember to change the Serial.begin to 9600. Let's hear the result.
