Hi guys!
I bought one of these ethernet modules:
I wired it up as the following:
VCC -- 3.3V
GND -- GND
CS -- 10
SCK -- 13
SO -- 12
SI -- 11
After I connect the module to the board,the red power indication LED lights up,but none of the ethernet LEDs on the front of the connector while it is connected to my router.
Should the ethernet LEDs light up or blink even if just power is applied to the module and connected to my router?If yes then is my module factory defective?
Test code:
#include <EtherCard.h>
#define STATIC 0 // set to 1 to disable DHCP (adjust myip/gwip values below)
// mac address
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
// ethernet interface ip address
static byte myip[] = { 192,168,0,200 };
// gateway ip address
static byte gwip[] = { 192,168,0,1 };
// LED to control output
int ledPin10 = 9;
byte Ethernet::buffer[700];
char const page[] PROGMEM =
"HTTP/1.0 503 Service Unavailable\r\n"
"Content-Type: text/html\r\n"
"Retry-After: 600\r\n"
"\r\n"
"<html>"
"<head><title>"
"Service Temporarily Unavailable"
"</title></head>"
"<body>"
"<h3>This page is used behind the scene</h3>"
"<p><em>"
"Commands to control LED are transferred to Arduino.
"The syntax: http://192.168.0.XX/?LED10=OFF or ON"
"</em></p>"
"</body>"
"</html>"
void setup () {
pinMode(ledPin10, OUTPUT);
Serial.println("Trying to get an IP...");
Serial.print("MAC: ");
for (byte i = 0; i < 6; ++i) {
Serial.print(mymac[i], HEX);
if (i < 5)
Serial.print(':');
if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
Serial.println( "Failed to access Ethernet controller");
Serial.println("Ethernet controller access: OK");
#if STATIC
Serial.println( "Getting static IP.");
if (!ether.staticSetup(myip, gwip)){
Serial.println( "could not get a static IP");
blinkLed(); // blink forever to indicate a problem
#else
Serial.println("Setting up DHCP");
if (!ether.dhcpSetup()){
Serial.println( "DHCP failed");
#endif
ether.printIp("My IP: ", ether.myip);
ether.printIp("Netmask: ", ether.netmask);
ether.printIp("GW IP: ", ether.gwip);
ether.printIp("DNS IP: ", ether.dnsip);
void loop () {
word len = ether.packetReceive();
word pos = ether.packetLoop(len);
// IF LED10=ON turn it ON
if(strstr((char *)Ethernet::buffer + pos, "GET /?LED10=ON") != 0) {
Serial.println("Received ON command");
digitalWrite(ledPin10, HIGH);
// IF LED10=OFF turn it OFF
if(strstr((char *)Ethernet::buffer + pos, "GET /?LED10=OFF") != 0) {
Serial.println("Received OFF command");
digitalWrite(ledPin10, LOW);
// show some data to the user
memcpy_P(ether.tcpOffset(), page, sizeof page);
ether.httpServerReply(sizeof page - 1);
void blinkLed(){
while (true){
