ENC28J60 read udp data stream in to array
Hi Folks
I'm using an arduino nano and an ENC28J60 with the following sketch that receives data and sends it back out to the dmx pin using the dmxsimple library, I am however struggling to get ANY data out and guess I'm doing something wrong in the conversion somewhere, the data coming in is UDP packets
#include "etherShield.h"
#include "ETHER_28J60.h"
#include <DmxSimple.h>
#define bytes_to_short(h,l) ( ((h << 8) & 0xff00) | (l & 0x00FF) );
int StartUniv = 0;
short incoming_universe=0; //leave as is (if suspect uni number issues, try changing first_uni number above first.
static uint8_t mac[6] = { 0xBE, 0xEF, 0x00, 0x00, 0x00, 0x00 }; // this just needs to be unique for your network,
static uint8_t ip[4] = {192, 168, 1, 15}; // IP address for the webserver
static uint16_t port = 6454; // ART NET udp port
byte channel[768]; // The number of channels to store data for
ETHER_28J60 e;
// The setup loop, executed only once before the main loop
DmxSimple.usePin(2);
DmxSimple.maxChannel(512);
e.setup(mac,ip , port);
Serial.print("I'm Alive");
char* EthernetData;
if (channel = e.serviceRequest())
  incoming_universe=bytes_to_short(EthernetData[15],EthernetData[14]);
if (incoming_universe == StartUniv)
      for(int i=0;i< 513;i++)
              DmxSimple.write(i, byte(EthernetData[i + 17]));
char* EthernetData;
EthernetData is a pointer that points nowhere. You can NOT use it like an array. You need a REAL array.
Ok, so now I'm stumped, with the wiznet it's just a simple matter of udp.read straight in to an array, any idea on how I do it with the ENC28j60's?
cheers
Mike
Anyone?
