Encoder algorithm
I’m writing some code to read a mouse encoder (ask if you want to know about hardware hack).
The code uses 2 interrupts/channels.
To decode the pulse train i use this code:
void interrupta()
counter = counter+((digitalRead(pinCha)^digitalRead(pinChb))^1)-(digitalRead(pinCha)^digitalRead(pinChb));
void interruptb()
counter = counter-((digitalRead(pinCha)^digitalRead(pinChb))^1)+(digitalRead(pinCha)^digitalRead(pinChb));
instead of use “if” statements i use xor gates
Do you think this code is faster than a “if” version?
“if” version:
.arduino.cc/playground/Main/RotaryEncoders (2 interrupts version)
Thanks
The if test is an order of magnitude faster than an digitalRead. You are looking in the wrong place for optimizing your code. Perhaps a peak a direct port manipulation would be useful: http://www.arduino.cc/en/Reference/PortManipulation
Given the overhead of “digitalRead”, I don’t think it matters.
(BTW, that’s an XOR operation, not a “gate”)
arduino.cc version.
void doEncoderA(){
// look for a low-to-high on channel A if (digitalRead(encoder0PinA) == HIGH) {
// check channel B to see which way encoder is turning if (digitalRead(encoder0PinB) == LOW) { encoder0Pos = encoder0Pos + 1; // CW } else { encoder0Pos = encoder0Pos - 1; // CCW } }
else // must be a high-to-low edge on channel A { // check channel B to see which way encoder is turning if (digitalRead(encoder0PinB) == HIGH) { encoder0Pos = encoder0Pos + 1; // CW } else { encoder0Pos = encoder0Pos - 1; // CCW } } Serial.println (encoder0Pos, DEC); // use for debugging - remember to comment out
new version:
void interrupta() {counter = counter+((digitalRead(pinCha)^digitalRead(pinChb))^1)-(digitalRead(pinCha)^digitalRead(pinChb)); }
Yes, this new version always make 4 digitalRead VS 2 or 3 digitalRread in the classic version
Where is the best place to post this question?
Thanks for your fast reply.
Not sure two different "digitalRead"s for each pin is legitimate - best to use variables.
Please use the # button when posting code.
Something like:
void interrupta()
a = digitalRead(pinCha);
b = digitalRead(pinChb);
counter = counter+((a^b)^1)-(a^b);
Let's exaggerate the times. Suppose it takes 1 minute to do a digitalRead, and 1 second to perform an if test.
Does it make sense to optimize the if tests or the digitalRead?
If you eliminate 2 if's by adding 2 digitalReads, your code is going to take twice as long to execute.
OK. Then the previous code:
  • has the same digitalReads than the original code (2)
  • has no if sentences
now i think is good enough.
direct port io manipulation…? that will be the next step but i have not idea about assembler.
thanks
direct port io manipulation...? that will be the next step but i have not idea about assembler.
No need for assembler code to do direct port commands, see:
I played with a couple of optical encoders a year ago or so and converting to direct port I/O Vs digitalRead commands was the single best improvement in step reponse speed.
Lefty
