Guys, I got a nice encode code working on my Arduino MEGA. BUT, I wish to use Interrupts, so I can check when the encoder is moved very fast and jump to MAX or MIN. Also bypass any problems of not checking the encoder code often…
So, here’s the code I’m using. But I got no clue on how to make it work with an Interrupt… :-[
#define dpInEncoderA 20
#define dpInEncoderB 19
int EncoderPos = 120;
int Position, Press;
int isForward = 0;
int Position2, Press2;
void ReadEncoder(int &rotate) { rotate = (digitalRead(dpInEncoderB) * 2) + digitalRead(dpInEncoderA); }
void ReadEncoderI()
ReadEncoder(Position2);
if (Position2 != Position)
int isFwd = ((Position == 0) && (Position2 == 1)) ||
((Position == 1) && (Position2 == 3)) ||
((Position == 3) && (Position2 == 2)) ||
((Position == 2) && (Position2 == 0));
if (isFwd) EncoderPos++; else EncoderPos--;
if (EncoderPos <= 0) EncoderPos = 1;
if (EncoderPos > 255) EncoderPos = 255;
Position = Position2;
// Encoder //
pinMode(dpInEncoderA, INPUT);
digitalWrite(dpInEncoderA, HIGH);
pinMode(dpInEncoderB, INPUT);
digitalWrite(dpInEncoderB, HIGH);
attachInterrupt(3,ReadEncoderI,CHANGE);
I’m pretty sure the code is all wrong, as its very late here and I’m very tired… :o :’(
Tomorrow I will run more tests and see if I can figure this one out. If I can’t, I will give up for the moment…
Wk
