Encoder gives values only in one way
I want to measure the distance that have been travelled. For this purpose I bought a motor with encoder. Its model is Mitsumi M25N
I did all the connections correct. Encoder works and its lights are on. I put 1k resistor on both digital outputs of encoder to 5V. When I rotated the motor by my hand, values are only goes to one way although I rotated both ways. I tried several codes I attached both of them can anyone tell me what is wrong?
int pulses;                              //Output pulses.
int deg = 0;
int encoderA = 3;
int encoderB = 2;                      //Direction of the motor.
int pulsesChanged = 0;
                  //Change speed of the motor.
void setup(){
  pinMode(encoderA, INPUT); //3
  pinMode(encoderB, INPUT); //2
  attachInterrupt(digitalPinToInterrupt(2), A_CHANGE, CHANGE);
}//setup
void loop(){
  if (pulsesChanged != 0) {
    pulsesChanged = 0;
    Serial.println(pulses);
void A_CHANGE(){                                  //Function that to read the pulses in x1.
  if( digitalRead(encoderB) == 0 ) {
    if ( digitalRead(encoderA) == 0 ) {
      // A fell, B is low
      pulses--; // moving reverse
      // A rose, B is low
      pulses++; // moving forward
  pulsesChanged = 1;
In this code I changed the way how interrupt triggered
int deg = 0;
int encoderA = 3;
int encoderB = 2;
const int pwm = 5;                      //Power of motor.
const int dir = 4;                       //Direction of the motor.
#define total 980                        //x4 pulses per rotation.
#define motorSpeed 180                   //Change speed of the motor.
  attachInterrupt(digitalPinToInterrupt(2), A_CHANGE, FALLING);
  attachInterrupt(digitalPinToInterrupt(3), B_CHANGE, FALLING);
}//setup
void loop(){
    pulsesChanged = 0;
void A_CHANGE(){
      // A fell, B is low
      // A rose, B is low
  }else {
      // B fell, A is high
      pulses++; // moving reverse
      // B rose, A is high
      pulses--; // moving forward
  pulsesChanged = 1;
void B_CHANGE(){
    if ( digitalRead(encoderB) == 0 ) {
      // B fell, A is low
      // B rose, A is low
  pulsesChanged = 1;
In the first code, you only trigger the interrupt handler when the A pin changes.
In the second code, you only trigger the interrupt handlers when the A and B pins fall.
You need to trigger both handlers when the corresponding pin CHANGES.
PaulS:
int encoderA = 3;
int encoderB = 2;
  attachInterrupt(digitalPinToInterrupt(3), A_CHANGE, CHANGE);
  attachInterrupt(digitalPinToInterrupt(2), B_CHANGE, CHANGE);
}//setup
void loop(){
    pulsesChanged = 0;
void A_CHANGE(){
      // A fell, B is low
      // A rose, B is low
  }else {
  pulsesChanged = 1;
void B_CHANGE(){
      // B fell, A is low
      //Serial.println("a");
      // B rose, A is low
      //Serial.println("b");
  pulsesChanged = 1;
In this case the output is like this :
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
-1
0
Did you look at the examples in the rotary encoder library? Why re-invent the wheel?
