Encoder knob count limits how do i do it
I'm using this code with an encoder that I'm using for a volume knob.
I want to only count between 1 and 300.
if I get to down to 1 or up to 300 it stops counting no matter how much i turn the knob.
thanks,
```cpp
enum PinAssignments {
encoderPinA = 3,
encoderPinB = 4,
clearButton = 8
volatile unsigned int encoderPos = 0;
unsigned int lastReportedPos = 1;
boolean A_set = false;
boolean B_set = false;
pinMode(encoderPinA, INPUT);
pinMode(encoderPinB, INPUT);
pinMode(clearButton, INPUT);
digitalWrite(encoderPinA, HIGH); // turn on pullup resistor
digitalWrite(encoderPinB, HIGH); // turn on pullup resistor
digitalWrite(clearButton, HIGH);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(1, doEncoderB, CHANGE);
void loop(){
if (lastReportedPos != encoderPos) {
Serial.print("Index:");
Serial.print(encoderPos, DEC);
lastReportedPos = encoderPos;
if (digitalRead(clearButton) == LOW) {
encoderPos = 0;
// Interrupt on A changing state
void doEncoderA(){
// Test transition
A_set = digitalRead(encoderPinA) == HIGH;
// and adjust counter + if A leads B
encoderPos += (A_set != B_set) ? +1 : -1;
// Interrupt on B changing state
void doEncoderB(){
// Test transition
B_set = digitalRead(encoderPinB) == HIGH;
// and adjust counter + if B follows A
encoderPos += (A_set == B_set) ? +1 : -1;
if encoderPos is less than 1, encoderPos = 1
if encoderPos is greater than 300, encoderPos = 300
If you provide complete information as recommended by the forum,
(" How to get the best out of this forum),
you will have a better chance of getting help.
Post a schematic of your project;
Which Arduino are you using?
How your project should work.
BTW, if using UNO/Nano/Mini, the interrupt pin are 2 and 3.
Not 3 and 4.
 encoderPinA = 3,
  encoderPinB = 4,
PS:
Try this code:
  encoderPinA = 3,
  encoderPinB = 2,
  clearButton = 8
volatile unsigned int encoderPos = 1;
    encoderPos = 1;
void doEncoderA() {
  // Test transition
  if(encoderPos < 1) encoderPos = 300;
void doEncoderB() {
  // Test transition
  if(encoderPos > 300) encoderPos = 1;
that works great
but
the 1 or 300 it needs to stop counting and not roll over.
for example
if I get to 300 and keep turning the knob up it stays at 300.
and doesn't roll over to 1
if I get to 1 and keep turning the knob down it stays at 1 and doesn't roll over to 300
Just modify these lines.
if(encoderPos < 1) encoderPos = 1
if(encoderPos > 300) encoderPos = 300;
Try
`encoderPos = constrain(encoderPos+(A_set != B_set ? +1 : -1));
Or
encoderPos = min(300, max(1,encoderPos+(A_set != B_set ? +1 : -1)))
