The standard quadrature encoder is specifically designed for position control, where you need to be
able to get back to the same position repeatably, so must use a signed counter.
If you just want speed control use only one channel of the encoder and count its pulses - ie attach
an interrupt for just one of the pins and increment the counter.
/* Encoder Library - Basic Example
http://www.pjrc.com/teensy/td_libs_Encoder.html
This example code is in the public domain.
// Variable 'counts' increments in either direction.
#include <Encoder.h>
// Change these two numbers to the pins connected to your encoder.
// Best Performance: both pins have interrupt capability
// Good Performance: only the first pin has interrupt capability
// Low Performance: neither pin has interrupt capability
Encoder myEnc(A0, A1);
// avoid using pins with LEDs attached
unsigned counts = -1;
Serial.println("Basic Encoder Test:");
long oldPosition = -999;
long newPosition = myEnc.read();
if (newPosition != oldPosition) {
oldPosition = newPosition;
counts++;
Serial.print(counts);
Serial.print("\t");
Serial.println(newPosition);
if (counts > 99) counts = 0;
Mind you, the code counts every transition, so four counts for each detent on my test manual encoder.
timtailors:
Using only one channel is too unprecise, the encoder also has an index pin for that pupose but using both channel works much better.
If you only count up regardless of turning left or right, how can you know how far you are moving?
I turn the motor till eg 100000 counts are reached after that I reset the encoder’s position to 0.
So that’s how I know how far the motor moved
If there is no other solution I would have done it as suggested in my first post.That doesn’t work as I can’t change the direction within the program but only when compiling
When you reset the position to 0, set a direction variable (1 or -1) and then just multiply this direction variable * the encoder position.
* http://www.pjrc.com/teensy/td_libs_Encoder.html
* This example code is in the public domain.
Encoder myEnc(5, 6);
int turnDirection = 1;
long newPosition = myEnc.read() * turnDirection;
if (newPosition = 1000 ) {
turnDirection = -turnDirection; // switch direction
myEnc.write(0); // reset position
