Encoder Library
Hello,
For a while now I have been using my own implementation for rotary encoders. I always thought that the following library was only for Teensy.
https://www.pjrc.com/teensy/td_libs_Encoder.html
Realizing that it is not, I attempted to implement it on the Due. I am without luck. I change Basic example to the pins I have been using for a while now, and the nothing is happening when I rotate the encoder.
My board and encoders are fine because I can see the signals with a scope and I have been using these boards for a year now.
I am using pins 18 and 19, which look to valid (I checked the pin configuration file) of the library.
I am using software version 1.6.3 with the teensyduino add-on.
EDIT:
The Basic example does not work, but the NoInterrupts example works. I would like to get the Basic example working. I feel like this is an internal problem.
Thanks, Daniel
The code isn't compatible with the Due interrupts as far as I can tell, lots of CORE_INTx_PIN #defines would be needed.
I figured,
I ended up using another method.
Thanks,
I'm the author of this library.....
MarkT: The code isn't compatible with the Due interrupts as far as I can tell, lots of CORE_INTx_PIN #defines would be needed.
In theory, there's lines in utility/interrupt_pins.h for Arduino Due. So it's supposed to work, with Due has working attachInterrupt(num, CHANGE).
In practice, little testing has been done. I really don't have time to test and troubleshoot the code for Due... but if anyone can, I'd be happy to accept a pull request for better defs or specific code for Due.
