Hello everyone!
I've been working on a project which involves the use of a GUI and control of an Arduino device. The control of the device has to be in real time so I'm sending a continuous stream of commands through the Serial port to the Arduino.
I'm using a Pololu micro motor and magnetic encoder to control the device and I want to impose a limit for the motor so that if the encoder of the motor reaches a certain value the motor stops.
Controlling the motor has been successful so far, but I cannot make the motor stop once the encoder reaches a certain value. Even if the encoder counts waayy above the limit value, the motor will still run.
I will post the code below:
void checkForCommand(){
if(Serial.available()){
do{ //Read serial input buffer data byte by byte for any received commands
receivedCommand = (char)Serial.read();
}while(Serial.available());
if(receivedCommand == '1'){
dataR=(char)Serial.read();
if(dataR=='F'){
while(dataR!='H' && motor1Count <= 15000){
digitalWrite(motor1pin1, LOW);
digitalWrite(motor1pin2, HIGH);
else if(dataR == 'B'){
while(dataR!='H' && motor1Count >= 6){
digitalWrite(motor1pin1, HIGH);
digitalWrite(motor1pin2, LOW);
Why is my code not taking into account the value of the encoder?
