encoder --measureing degrees
/* this program is write from my observatory. im using the arduino 2560 mega with two incremental 600 pulse encoder thats is connect a gear to increase the pulse count from 600 to 24000. i got the altitude encoder working. the azimuth encoder is count from 0 to 359 or 359 to 0 and the where my problem start. there is more to this program that i didnt need help at this point. */
enc_1A = 21;
enc_1B = 20;
enc_2A = 18;
enc_2B = 19;
volatile int lastEncoded1 = 0;
volatile long encoderValue1 = 0;
volatile int lastEncoded2 = 0;
volatile long encoderValue2 = 0;
int azm;
int Alt;
pinMode(enc_1A, INPUT_PULLUP);
pinMode(enc_1B, INPUT_PULLUP);
pinMode(enc_2A, INPUT_PULLUP);
pinMode(enc_2B, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(enc_1A), Encoder1, CHANGE);
attachInterrupt(digitalPinToInterrupt(enc_1B), Encoder1, CHANGE);
attachInterrupt(digitalPinToInterrupt(enc_2A), Encoder2, CHANGE);
attachInterrupt(digitalPinToInterrupt(enc_2B), Encoder2, CHANGE);
// cos_phi = cos((((latHH * 3600) + (latMM * 60) + latSS) / 3600.0) * pi / 180.0);
//sin_phi = sin((((latHH * 3600) + (latMM * 60) + latSS) / 3600.0) * pi / 180.0);
// TSL = poleAR_HH * 3600 + poleAR_MM * 60 + poleAR_SS + poleH_HH * 3600 + poleH_MM * 60 + poleH_SS;
//while (TSL >= 86400) TSL = TSL - 86400;
t_ciclo = millis();
if (t_ciclo_acumulado >= seg_sideral) {
TSL++;
t_ciclo_acumulado = t_ciclo_acumulado - seg_sideral;
if (TSL >= 86400) {
TSL = TSL - 86400;
read_sensors();
/*AZ_to_EQ();
if (Serial.available() > 0) communication();
t_ciclo = millis() - t_ciclo;
t_ciclo_acumulado = t_ciclo_acumulado + t_ciclo;
void communication()
int i = 0;
input[i++] = Serial.read();
delay(5);
while ((input[i++] = Serial.read()) != ‘#’) {
delay(5);
input = ‘\0’;
  • if (input[1] == ‘:’ && input[2] == ‘G’ && input[3] == ‘R’ && input[4] == ‘#’) {*
  • Serial.print(txAR);*
  • if (input[1] == ‘:’ && input[2] == ‘G’ && input[3] == ‘D’ && input[4] == ‘#’) {*
  • Serial.print(txDEC);*
    _ }/_
    void read_sensors() {
    // encoder pulse is 24000and66.6667 pulses per degree
    alt = encoderValue1 / 66.6667; //this work
    _/
    this part will count from 0 to 359 clockwise but if count clockwise it goes -1 to - 359. when it reaches 359 it keep counting 360, 361, 362, ect_
    this is when im missing something or doing it wrong*/
    if encoderValue2 =0 || encoderValue2 = 24000{ // count from 0 to 359 clockwise
  • azm = encoderValue2 / 66.6667;*
    *if encoderValue2 <= -1{ counts from 359 to 0 counter clockwies *
  • azm = 359*
    if encoderValue2 >= 24001{ //when the count reach 359 then reset 0 zero and starts count from 0 to 359
  • azm = 0*
    void Encoder1() {
  • int encoded1 = (digitalRead(enc_1A) << 1) | digitalRead(enc_1B);*
  • int sum = (lastEncoded1 << 2) | encoded1;*
  • if (sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue1 ++;*
  • if (sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue1 --;*
  • lastEncoded1 = encoded1;*
    void Encoder2() {
  • int encoded2 = (digitalRead(enc_2A) << 1) | digitalRead(enc_2B);*
  • int sum = (lastEncoded2 << 2) | encoded2;*
  • if (sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue2 ++;*
  • if (sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue2 --;*
  • lastEncoded2 = encoded2;*
Use code tags, your code got garbled (see the italics?)
One thing I see:
Should be:
if encoderValue2 == 0 || encoderValue2 == 24000{ // count from 0 to 359 clockwise
= vs ==.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
edgemoron:
One thing I see:
Should be:
= vs ==.
Neither of those will work since if expressions are enclosed in parentheses:
if (encoderValue2 == 0 || encoderValue2 == 24000)
{ // count from 0 to 359 clockwise[/code] = vs ==
There were MANY invalid characters and typographical errors in the code you posted. It was not even close to being compilable. Your functionality problem was due to logic errors. I have fixed everything for you:
const byte enc_1A = 21;
const byte enc_1B = 20;
const byte enc_2A = 18;
const byte enc_2B = 19;
int azm;
int Alt;
      t_ciclo = millis();
       TSL++;
       if (TSL >= 86400) {
         TSL = TSL - 86400;
  read_sensors();
  /*AZ_to_EQ();
    int i = 0;
     delay(5);
     while ((input[i++] = Serial.read()) != '#') {
       delay(5);
     input[i] = '\0';
     if (input[1] == ':' && input[2] == 'G' && input[3] == 'R' && input[4] == '#') {
       Serial.print(txAR);
     if (input[1] == ':' && input[2] == 'G' && input[3] == 'D' && input[4] == '#') {
  // encoder pulse is 24000 and 66.6667 pulses per degree
  Alt = encoderValue1 / 66.6667; //this work
  /* this part will count from 0 to 359 clockwise but if count clockwise it goes -1 to - 359. when it reaches 359 it keep  counting 360, 361, 362, ect
void Encoder1() {
  if (sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) {
    encoderValue1++;
    if (encoderValue1 >= 24000)
      encoderValue1 -= 24000;
  if (sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) {
    encoderValue1 --;
    if (encoderValue1 < 0)
      encoderValue1 += 24000;
void Encoder2() {
    encoderValue2 ++;
    if (encoderValue2 >= 24000)
      encoderValue2 -= 24000;
    encoderValue2 --;
    if (encoderValue2 < 0)
      encoderValue2 += 24000;
