Encoder menu help!!! im stuck
So this is what I am trying to use here but I cannot compile while im getting the following error messages. any help is appreciated.
// Include Standard Library
#include <stdlib.h>
// Include LCD Library Code
#include <LiquidCrystal.h>
// Include Rotary Encoder Library
#include <QuadEncoder.h>
#include <Button.h>
// control
#define ROTENCA 43
#define ROTENCB 45
#define BUTTONR 2 // Intr 0 = Pin 2
#define BUTTON 1 // Intr 1 = Pin 3
// modes
#define MODE_DISPLAY 0
#define MODE_COUNT 1
#define LAST_MODE 1
// initialize the LCD with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// initialize the encoder
QuadEncoder encoder(ROTENCA,ROTENCB); // initialize the encoder
// has the encoder moved on this loop?
boolean moved = false;
Button buttonR(BUTTONR);
// other vars
int mode = MODE_DISPLAY;
int count = 0;
unsigned long timeSinceLastDisplay = 0;
// setup interrupts
attachInterrupt(BUTTON, displayMenu, RISING);
// set the LCD’s number of cols and lines
lcd.begin(16, 2);
// print a welcome message
lcd.clear();
lcd.print(" WELCOME! ");
lcd.setCursor(0,1);
lcd.print(“Initializing”);
displayMenu() {
int selected = 3;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(“Turn the knob to”);
lcd.setCursor(0,1);
lcd.print(“select an option”);
while (!buttonR.pressed()) {
selected += readEncoder();
if (selected<0) selected=3;
if (selected>3) selected=0;
if (moved) {
lcd.clear();
lcd.setCursor(0,0);
switch(selected) {
case 0:
lcd.print("Change Units ");
case 1:
lcd.print(“Backlight On/Off”);
case 2:
lcd.print("Logging On/Off ");
case 3:
lcd.print("Exit Settings ");
// when button is pressed…
lcd.clear();
switch(selected) {
case 0:
settingsChangeUnits();
case 1:
settingsChangeBacklight();
case 2:
settingsChangeLogging();
void settingsChangeUnits() {
int selected = 2;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Select Unit ");
lcd.setCursor(0,1);
lcd.print("Currently it’s ");
lcd.write();
if (selected<0) selected=2;
if (selected>2) selected=0;
if (moved) {
lcd.setCursor(0,1);
switch(selected) {
case 0:
lcd.print("Celcius ");
case 1:
lcd.print("Fahrenheit ");
case 2:
lcd.print("Cancel ");
j…
switch(selected) {
case 0:
temperatureUnit = ‘C’;
case 1:
temperatureUnit = ‘F’;
// returns 1 for right, -1 for left, or 0 for no movement
int readEncoder() {
moved = true;
switch(encoder.hb()) {
case ‘>’: return 1;
case ‘<’: return -1;
moved = false;
return 0;
I am getting the following errors.
temp_menu_test_test_test.ino: In function ‘void setup()’:
temp_menu_test_test_test:133: error: a function-definition is not allowed here before ‘{’ token
temp_menu_test_test_test:148: error: a function-definition is not allowed here before ‘{’ token
temp_menu_test_test_test:461: error: expected `}’ at end of input
You appear to have missed the closing curly brace at the end of your setup function.
--best, Michael
