Encoder nidec 24h404h070
code test:
#include <ServoTimer2.h>
#define PWM_1 9
#define DIR_1 7
#define PWM_2 10
#define DIR_2 5
#define ENC_1 2
#define ENC_2 3
#define BRAKE 8
#define BUZZER 12
#define VBAT A7
float loop_time = 50;
volatile byte pos;
volatile int enc_count = 0;
int16_t motor_speed;
int f = 1;
boolean lock = 1;
long currentT, previousT_1, previousT_2 = 0;
ServoTimer2 steering_servo;
void beep() {
digitalWrite(BUZZER, HIGH);
delay(70);
digitalWrite(BUZZER, LOW);
delay(80);
void Motor1_control(int sp) {
if (sp > 0) digitalWrite(DIR_1, LOW);
else digitalWrite(DIR_1, HIGH);
analogWrite(PWM_1, 255 - abs(sp));
void Motor2_control(int sp) {
if (sp > 0) digitalWrite(DIR_2, LOW);
else digitalWrite(DIR_2, HIGH);
analogWrite(PWM_2, 255 - abs(sp));
void ENC_READ() {
byte cur = (!digitalRead(ENC_1) << 1) + !digitalRead(ENC_2);
byte old = pos & B00000011;
byte dir = (pos & B00110000) >> 4;
if (cur == 3) cur = 2;
else if (cur == 2) cur = 3;
if (cur != old) {
if (dir == 0) {
if (cur == 1 || cur == 3) dir = cur;
if (cur == 0) {
if (dir == 1 && old == 3) enc_count--;
else if (dir == 3 && old == 1) enc_count++;
dir = 0;
pos = (dir << 4) + (old << 2) + cur;
// Pins D9 and D10 - 7.8 kHz
TCCR1A = 0b00000001; // 8bit
TCCR1B = 0b00001010; // x8 fast pwm
steering_servo.attach(A3);
steering_servo.write(1500);
pinMode(DIR_1, OUTPUT);
pinMode(DIR_2, OUTPUT);
pinMode(BRAKE, OUTPUT);
pinMode(BUZZER, OUTPUT);
pinMode(ENC_1, INPUT);
pinMode(ENC_2, INPUT);
Motor1_control(0);
Motor2_control(0);
attachInterrupt(0, ENC_READ, CHANGE);
attachInterrupt(1, ENC_READ, CHANGE);
currentT = millis();
if (currentT - previousT_1 >= loop_time) {
motor_speed = -enc_count;
enc_count = 0;
switch (f) {
  case 1:
    if (lock) Serial.println("phan hoi cua servo...");
    lock = 0;
  case 2:
    digitalWrite(BRAKE, HIGH);
    if (lock) Serial.println("hienthi rotating reaction wheel (clockwise).");
    lock = 0;
    Motor1_control(-30);
  case 3:
    if (lock) Serial.println("Speed up.");
    lock = 0;
    Motor1_control(-60);
  case 4:
    lock = 0;
    Motor1_control(-110);
  case 5:
    digitalWrite(BRAKE, LOW);
    if (lock) Serial.println("Stop.");
    lock = 0;
    Motor1_control(0);
  case 6:
    if (lock) Serial.println("hienthi rotating reaction wheel (counter clockwise).");
    lock = 0;
    Motor1_control(30);
  case 7:
    lock = 0;
    Motor1_control(60);
  case 8:
    lock = 0;
    Motor1_control(110);
  case 9:
    lock = 0;
    Motor1_control(0);
  case 10:
    if (lock) Serial.println("Checking encoder...");
    lock = 0;
 case 11:
    if (lock && motor_speed > 20) {
      Serial.println("Encoder OK.");
      Serial.print("Speed: "); Serial.println(motor_speed);
    } else if (lock && motor_speed <= 0) {
      Serial.println("Encoder FAIL.");
    lock = 0;
    Motor1_control(0);
 case 12:
    if (lock) Serial.println("xet chieu steering servo (to left)...");
    lock = 0;
    steering_servo.write(1200);
 case 13:
    if (lock) Serial.println("xet chieu steering servo (to right)...");
    lock = 0;
    steering_servo.write(1800);
 case 14:
    if (lock) Serial.println("xet chieu steering servo (to center)...");
    lock = 0;
 case 15:
    if (lock) Serial.println("hienthi rotating rear wheel (forward).");
    lock = 0;
    Motor2_control(30);
  case 16:
    lock = 0;
    Motor2_control(60);
  case 17:
    lock = 0;
    Motor2_control(110);
  case 18:
    lock = 0;
    Motor2_control(0);
  case 19:
    if (lock) Serial.println("hienthi (backward).");
    lock = 0;
    Motor2_control(-30);
  case 20:
    lock = 0;
    Motor2_control(-60);
  case 21:
    lock = 0;
    Motor2_control(-110);
  case 22:
    lock = 0;
    Motor2_control(0);
previousT_1 = currentT;
if (currentT - previousT_2 >= 3000) {
f++;
if (f == 23) {
f = 1;
Serial.println("Beep!");
beep();
lock = 1;
previousT_2 = currentT;
p/s: encoder has a negative sign
Please read and use the topic How to get the best out of this forum - Using Arduino / IDE 1.x - Arduino Forum
