Salve, ho adattato uno sketch per convertire la rotazione dell’encoder in una misura lineare,
tutto funziona bene ma non riesco a resettare il valore letto tramite il pulsante SW dell’encoder.
Sicuramente mi sto perdendo in un bicchiere d’acqua, mi aiutate a capire dove sbaglio?
Metto qui sotto il codice ( necessita di “MsTimer2.h”) ed è OK sia su seriale che LCD :
* rotary_sm.ino -- State machine implementation of rotary encoder driver
* Interrupt driven; supports 2 types of interrupts:
* * Polled interrupts; enable by defining TIMER2INT
* * Pin change interrupts: enalbe by defining PINCHANGEINT
* (Do NOT enable both at the same time)
* This program is developed from the code at:
* http://www.buxtronix.net/2011/10/rotary-encoders-done-properly.html
* Since this code was in the form of an arduino library, and I had unresolvable
* references that I could not figure out, I just modified it as a single sketch.
* The only library support required is if you want to use interrupt polling,
* and then the MsTimer2 library needs to be installed.
#include <Wire.h>
#include <LiquidCrystal_I2C.h> // Libreria LCD I2C
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);//Inizializzo LCD
/* Define PINCHANGEINT if you want to interrupt on any encoder pin change */
//#define PINCHANGEINT
/* --- OR --- */
/* Define TIMER2INT if you want to use periodic interrupts to poll the encoder */
#define TIMER2INT
/* Define ENABLEPULLUPS if there are no external pull-ups on encoder AB pins */
//#define ENABLEPULLUPS
/* Define to enable the ISR debug flag */
#define ISRFLAG
/* You may need to install this library (MsTimer2) from the arduino site */
#ifdef TIMER2INT
#include <MsTimer2.h>
#endif
#define DIR_NONE 0x00 // No complete step yet.
#define DIR_CW 0x10 // Clockwise step.
#define DIR_CCW 0x20 // Anti-clockwise step.
unsigned int state;
unsigned int A = 2; // pins connected to the encoder (digital_pin 2)
unsigned int B = 3; // " (digital_pin 3)
unsigned int ISRflag = 5; // " (digital_pin 3)
int count = 0; // count each indent
int old_count = 0; // check for count changed
unsigned int PinSW = 4;
float lettura ;
* The below state table has, for each state (row), the new state
* to set based on the next encoder output. From left to right in,
* the table, the encoder outputs are 00, 01, 10, 11, and the value
* in that position is the new state to set.
// State definitions state table (emits a code at 00 only)
// states are: (NAB) N = 0: clockwise; N = 1: counterclockwiswe
#define R_START 0x3
#define R_CW_BEGIN 0x1
#define R_CW_NEXT 0x0
#define R_CW_FINAL 0x2
#define R_CCW_BEGIN 0x6
#define R_CCW_NEXT 0x4
#define R_CCW_FINAL 0x5
const unsigned char ttable[8][4] = {
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START}, // R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_BEGIN, R_START}, // R_CW_BEGIN
{R_CW_NEXT, R_CW_FINAL, R_CW_FINAL, R_START | DIR_CW}, // R_CW_FINAL
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START}, // R_START
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START}, // R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_FINAL, R_START | DIR_CCW}, // R_CCW_FINAL
{R_CCW_NEXT, R_CCW_BEGIN, R_CCW_BEGIN, R_START}, // R_CCW_BEGIN
{R_START, R_START, R_START, R_START} // ILLEGAL
void setup( ) {
pinMode( A, INPUT );
pinMode( B, INPUT );
pinMode(PinSW, INPUT);
#ifdef ENABLEPULLUPS
digitalWrite( A, HIGH ); // set pullups
digitalWrite( B, HIGH ); // "
digitalWrite( PinSW, HIGH );
#endif
#ifdef TIMER2INT
MsTimer2::set( 1, T2_isr ); // interrupt polling:
MsTimer2::start( );
#endif
#ifdef PINCHANGEINT
attachInterrupt( 0, AB_isr, CHANGE ); // pin-change interrupts:
attachInterrupt( 1, AB_isr, CHANGE );
#endif
#ifdef ISRFLAG
pinMode( ISRflag, OUTPUT ); // time the ISR
digitalWrite( ISRflag, HIGH ); // set pull-up ON
#endif
state = (digitalRead( A ) << 1) | digitalRead( B ); // Initialise state.
old_count = 0;
Serial.begin( 9600 );
Serial.println( "Rotary Encoder Tests" );
lcd.begin(16,2);
lcd.clear();
#ifdef PINCHANGEINT
void AB_isr( ) {
// Grab state of input pins.
unsigned char pinstate = (digitalRead( A ) << 1) | digitalRead( B );
// Determine new state from the pins and state table.
state = ttable[state & 0x07][pinstate];
if( state & DIR_CW ) count++;
if( state & DIR_CCW ) count--;
#endif
#ifdef TIMER2INT
void T2_isr( ) {
#ifdef ISRFLAG
#endif
if( state & DIR_CW ) count++; // count up for clockwise
if( state & DIR_CCW ) count--; // count down for counterclockwise
#ifdef ISRFLAG
digitalWrite( ISRflag, LOW );
#endif
#endif
void loop( ) {
if( old_count != count ) {
old_count = count;
lettura = (count * 0.15); // Ad ogni Step assegno 0,15mm che corrispondono a 3mm giro
lcd.setCursor(0,0);
lcd.print("X= ");
lcd.print( lettura );
lcd.print(" mm ");
lcd.setCursor(0,1);
lcd.print( count );
lcd.print(" ");
Serial.print (lettura);
Serial.print (" mm Posizione Encoder ");
Serial.println( count );
if( PinSW == LOW ) { // Reset contatore
count = 0;
Con l’ultima istruzione pensavo di resettare il contatore, ma non funziona…dove sto sbagliando?
Abbiate pietà, sono un niubbo
