Encoder problema
Sto realizzando un timer…
Il problema è che quando vado a cambiare il tempo da minuti a secondi mi decrementa di un unità il blocco successivo;
Ovvero se sono su i minuti e schiaccio il pulsante per cambiare i secondi diminuiranno di uno;
Il problema è che non esegue sempre questo errore, dove è l’errore?
#include <TM1637Display.h>
 #define CLK 2
#define DIO 3
 #define outputA 7
 #define outputB 8
 const int ledPin = 13;
 const int buttonPin =  6;
 int ledState = 1;
 int buttonState;
 int lastButtonState = 0;
 unsigned long lastDebounceTime = 0;
 unsigned long debounceDelay = 50;
/*int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
 int click = 0;
 int clickState;
 int secondi = 0;
 int minuti = 0;
 int aState;
 int aLastState;
 int aState_;
 int aLastState_;
TM1637Display display(CLK, DIO);
   pinMode (outputA,INPUT);
   pinMode (outputB,INPUT);
   pinMode (buttonPin, INPUT);
   pinMode(ledPin, OUTPUT);
   Serial.begin (9600);
   aLastState = digitalRead(outputA);
   aLastState_ = digitalRead(outputA);
  int reading = digitalRead(buttonPin);
  if (reading != lastButtonState) {
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
     if (reading != buttonState) {
      buttonState = reading;
     if (buttonState == 0) {
        ledState = !ledState;
      digitalWrite(ledPin, ledState);
  if(ledState == 1){
    click = 1;
  }else{
    click = 0;
  lastButtonState = reading;
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button went from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
  // turns on the LED every four button pushes by checking the modulo of the
  // button push counter. the modulo function gives you the remainder of the
  // division of two numbers:
  if (buttonPushCounter % 2 == 0) {
    digitalWrite(ledPin, HIGH);
    click = 0;
    digitalWrite(ledPin, LOW);
    click = 1;
  switch(click){
    case 0:
      seconds();
    case 1:
      minutes();
 void seconds(){
    Serial.println(secondi);
    display.setBrightness(7, true);
    display.showNumberDec(secondi, true, 2, 2);
    aState = digitalRead(outputA);
    if (aState != aLastState){
     if (digitalRead(outputB) != aState) {
       secondi ++;
       if(secondi > 59){
        secondi = 0;
       secondi --;
       if(secondi < 0){
        secondi = 59;
     Serial.print("SECONDI: ");
   aLastState = aState;
 void minutes(){
  Serial.println(minuti);
   display.showNumberDec(minuti, true, 2, 0);
  aState_ = digitalRead(outputA);
    if (aState_ != aLastState_){
     if (digitalRead(outputB) != aState_) {
       minuti ++;
       if(minuti > 99){
        minuti = 0;
       minuti --;
       if(minuti < 0){
        minuti = 99;
     Serial.print("MINUTI: ");
   aLastState_ = aState_;
hai messo le resistenze di pulldown (o comunque un debounce hardware) sui pin in input?...hai fatto un debounce software per un ingresso...e per gli altri due?
Ho fatto il debounce via software come puoi vedere dal codice, riguardo alla rotazione dell'encoder non ho problemi, per precauzione ho anche cambiato pulsante usando un comunissimo pushbutton ma il risultato non cambia
certo che per complicarsi la vita ce la mettiamo tutta :slight_smile:
pinMode (outputA, INPUT);
pinMode (outputB, INPUT);
analizziamo il loop
premo il button
reading diventa = 1
se reading != buttonstate (=0) quindi entro nell'if
carico lastDebounceTime
non sono ancora passati 50 ms quindi non entro nell'if
metto ledPin = ledState (=1 da dichiarazione iniziale variabili)
entro nell'if ledState==1
e click diventa = 1
lastButtonState diventa = 1 (reading=1)
caso1 quindi minutes()
vado avanti con il programma
domanda:
il debounce che effetto ha?
