Hi all! I decided to make blinking LEDs using an atmega168pa encoder. Individually, the LEDs "run" perfectly to the left when the encoder is turned to the left and to the right when the encoder is turned to the right. I have a conflict when combining these modes so that the LEDs blink left and right. What could be the problem? Here is my code:
ISR(ADC_vect) {
//PORTC |= (1 << PC1); // turn on the LED clockwise
uint16_t val = ADC;
// Determine the current state of the encoder depending on the value on pin PC3
if (val > 1023 * 0.95) {
enc_state = 0b00000000;
} else if (val > 1023 * 0.47 && val < 1023 * 0.53) { // according to documentation (val > 1023 * 0.47 && val < 1023 * 0.53)
enc_state = 0b00000010;
} else if (val > 1023 * 0.37 && val < 1023 * 0.43) { // according to documentation (val > 1023 * 0.37 && val < 1023 * 0.43)
enc_state = 0b00000011;
} else if (val > 1023 * 0.65 && val < 1023 * 0.68) { // according to documentation (val > 1023 * 0.65 && val < 1023 * 0.68)
enc_state = 0b00000001;
if (enc_state != lastState) { // if the state has changed
if ((lastState == 0b00000001 && enc_state == 0b00000011) || // if the sequence is 01 -> 11 -> 10 -> 00
(lastState == 0b00000011 && enc_state == 0b00000010) ||
(lastState == 0b00000010 && enc_state == 0b00000000) ||
(lastState == 0b00000000 && enc_state == 0b00000001)) {
enc_dir = 1;
PORTC &= ~(_BV(PC0)); // turn off the LED counterclockwise
PORTC |= _BV(PC1); // turn on the LED clockwise
else if ((lastState == 0b00000001 && enc_state == 0b00000000) || // if the sequence is 01 -> 00 -> 10 -> 11
(lastState == 0b00000000 && enc_state == 0b00000010) ||
(lastState == 0b00000010 && enc_state == 0b00000011) ||
(lastState == 0b00000011 && enc_state == 0b00000001)) {
enc_dir = -1;
PORTC &= ~(_BV(PC1)); // turn off the LED clockwise
PORTC |= _BV(PC0); // turn on the LED counterclockwise
else{
enc_dir = 0;
lastState = enc_state; // remember the current state of the encoder
_delay_us(60);
ADCSRA |= (1 << ADSC); // Starting the next measurement
