encoder
I am trying for the Adruino Uno to read a pulse from a optical encoder. I have the index from the encoder going to pin#2 as an input. What kind of voltage change can the Adruino see? Right now at "index" I get the 5 volts but out of index the voltage stays at about 2 volts. Is this voltage change enough for the Arduino to detect it from "LOW" to "HIGH"?
jcann9960: I am trying for the Adruino Uno to read a pulse from a optical encoder. I have the index from the encoder going to pin#2 as an input. What kind of voltage change can the Adruino see? Right now at "index" I get the 5 volts but out of index the voltage stays at about 2 volts. Is this voltage change enough for the Arduino to detect it from "LOW" to "HIGH"?
The forward voltage of a (silicon) diode is about 0.7V, you could try that to drop your LOW. there are more electronic methods... transistor, level shifter, resistors, etc...
Assuming Uno you need about 5V to register a HIGH, but you can look at the datasheet for that.
BulldogLowell: The forward voltage of a (silicon) diode is about 0.7V, you could try that to drop your LOW. there are more electronic methods... transistor, level shifter, resistors, etc...
The datasheet says below 1.5 is LOW and above 3.0 is HIGH, but a recent thread in Project Guidance has shown that may not be the whole story.
Delta_G: The datasheet says below 1.5 is LOW and above 3.0 is HIGH, but a recent thread in Project Guidance has shown that may not be the whole story.
my error! I meant 3.0V...
thanks!
(deleted)
